Post new topic Reply to topic  [ 5 posts ]
PostPosted: Thu Sep 06, 2012 9:54 pm
I would like this a lot except for being made from plastic.
Adjustable to 10mm, 11mm, 12mm, 13mm and 15mm height
PostPosted: Fri Sep 07, 2012 2:54 am
Cool idea. Agreed though that the plastic is a bit sketchy.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Fri Sep 07, 2012 3:19 am
I find composite spacers often produce the mysterious creaking sound.
Highline Search Group | http://www.highlinesearch.com | Outdoor & Sporting Goods Recruiters
PostPosted: Fri Sep 07, 2012 4:28 am
In compression thermoset (and nearly all clear plastics are thermoset) work just fine, noting that CF headset spacers are over 50% plastic and the fibres don't do that much in compression......
I've looked at ally spacers of a similar design but they were heavier than CF ones, especially the lightweight (13g for 50mm) BBB 'formed' ones.
PostPosted: Fri Sep 07, 2012 5:41 am
I use the clear version for 5000+km on the road. No creaking, no problems...
Users browsing this forum: bonedpwinkle and 11 guests
There are no new unread posts for this topic. Installing Red 2013 crank -- what is the plastic spacer for?
VTBike
7
631
Thu Apr 25, 2013 4:23 am
There are no new unread posts for this topic. Looking for white tapered headset spacer
iscarrr
Mon Oct 01, 2012 6:49 am
iscarrr View the latest post
There are no new unread posts for this topic. FSA headset zero stack cone spacer
Fri Feb 08, 2013 11:02 pm
113245 View the latest post
There are no new unread posts for this topic. Supersix Headset Conical Spacer Replacement
svm
Wed Mar 27, 2013 3:58 pm
mvz2 View the latest post
There are no new unread posts for this topic. Now this is interesting..DI2 wires anyone?
maverick_1
Mon Jun 11, 2012 1:44 pm
gazrichards View the latest post
It is currently Sat May 18, 2013 6:31 pm
