Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Thu Aug 23, 2012 2:27 am
I am thinking about getting a carbon 29'er with rigid fork. Just for gravel paths and some mild single track.
Questions.
I have pretty much all of the component that I need save the wheels and frame/forks. I am currently running XX derailleurs, shifters and cassette, will buy some new XX brakes, Syntace stem, Easton bars and Thomson post.
I am unsure of the gearing and what wheels to get.
Frame can be bought in BB30 or BSA - I currently have 2 cranks (44t/30t Extralite on carbon cranks and 32t carbon spiderless ring on carbon cranks) I am willing to sell both cranks to buy a BB30 set up but is it that much better?
Wheels - I was thinking of getting some Stan's No Tubes Crest ZTR 29er wheelset which would mean having to get some new tires as well. Any thoughts on tires?
Everything else is sorted out for components. and I will run the stem negetive to lower the front end a bit.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Thu Aug 23, 2012 9:58 am
Administrator
I like both Continental Race Kings and the much lighter Rocket Ron's. Keep in mind that they work well with the soil conditions of the Midwest. With your back issues are you looking at a low rise wider bar? (Probably a good idea) If you have serious climbs a 11-34 or 11-36 might be the way to go. I'm not going to be much help on cranks since I ride XT with a ceramic bottom bracket converted to pulley use.
PostPosted: Thu Aug 23, 2012 4:01 pm
44 is probably too tall. The XX cranks come with a 39 outer ring for 29er applications and with a 11 that will really get you going on anything but the steepest descents.
PostPosted: Sun Aug 26, 2012 9:53 pm
Bear in mind you will need a approx 4 tooth smaller chainring on a 29er to get the same ratios as a 26er with the same cassette. I generally used a 36t or 38t single ring on my 26er race bike but 32t or 34t on the 29er. Its suprising how many don't work out the difference needed!
PostPosted: Sun Aug 26, 2012 9:58 pm
Well lucky I have a custom make 32t carbon spiderless chainring in the garage so I should be fine if I can sell the 26" bike first. I am thinking about going single front anyways.
BIG DADDY B FLOW
PostPosted: Sun Aug 26, 2012 10:03 pm
Sounds made for the job! Rare that you will run out of gears on a 32 and the 32/36 gives you a pretty good climbing gear
PostPosted: Sun Aug 26, 2012 10:12 pm
Only issue is that the cranks is make for BSA and not BB30 which I would like to go with this time.
BIG DADDY B FLOW
PostPosted: Sun Aug 26, 2012 10:21 pm
For sure you can get adaptors to run hollowtech 2 chainsets in bb30 frames. take a look at ultimate ceramic bearings website. they have some listed and sure must be others available also
PostPosted: Sun Aug 26, 2012 10:29 pm
Or I could go with BB30 and pick up some sweet Cannondale cranks which would allow me to remove spider and buy another carbon spider.
BIG DADDY B FLOW
PostPosted: Mon Aug 27, 2012 3:58 am
Nowhere near as bling as SiSL, but SRAM can be good value for money.
Not bad weight considering that the cranks can go for under $100 new on eBay.
Carbon saves a bit of weight and both the Aluminum and Carbon cranks come in BB30 versions which are lighter than GXP.
If you do go BB30 and can get them from the USA, S-Works is definitely the best value for money by far. $300 for one of the lightest set ups out there, much easier on the wallet than SiSL.
PostPosted: Mon Aug 27, 2012 4:46 am
Thanks for the heads up as that will allow for a cheaper set up with not a bad weight penalty. I am still very unsure about going 32t front only or going with a 2 X 10 set up. 1 X 10 set up would most likely stick with thumb shifters but if I go 2 X 10 then I am going grip shift for sure.
1 X 10 would be a less expensive set up for sure.
BIG DADDY B FLOW
PostPosted: Mon Aug 27, 2012 5:05 am
Carbon-Ti also do a spiderless double set up for most of the new spiderless cranks too. Pretty cheap/light way to 'bling-up' SRAM cranks. The S-Works cranks fit the Lightning 104/64 spider which weighs less than pretty much all the Spec. versions and lets you run normal rings without much of a weight penalty also.
PostPosted: Mon Aug 27, 2012 2:21 pm
shameless plug, I have a road version of the c-dale sisl for sale in the classifieds. PM me if interrested, 575$ shipped or make an offer ;)
also have a bb and tools... :P
2013 rocky mountain vertex 29er
­Twitter
www.cyclingtrainingnuts.blogspot.ca
PostPosted: Mon Aug 27, 2012 2:40 pm
Well nothing is going to happen unless I can sell the PF MT frame in the classifieds as well. Until such time, I have to just look. If that does not sell then I will buy the Trigon Carbon fork and just keep the bike and stick with 26" which is not what I want to do. I think if I am going to stick with full rigid that it would be better to move up to 29" and have a higher front end for my back.
BIG DADDY B FLOW
PostPosted: Mon Aug 27, 2012 7:32 pm
@jooo - What cranks are those from Sram.
BIG DADDY B FLOW
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 11 guests
There are no new unread posts for this topic. WTB MTB hubs, 29'er carbon rims
in Wanted
Martin.F
Thu Apr 04, 2013 11:12 pm
Martin.F View the latest post
There are no new unread posts for this topic. Looking for a nice rigid carbon 29'er fork
in MTB
tomp
Wed Oct 31, 2012 6:05 pm
Werdna View the latest post
There are no new unread posts for this topic. Advice for a full aluminum full suspension 29'er
in MTB
tomp
Tue Sep 11, 2012 9:32 pm
neiloxford View the latest post
There are no new unread posts for this topic. fit questions
firstcaad
7
507
Sun Jan 13, 2013 3:40 pm
DaveS View the latest post
It is currently Sat May 25, 2013 10:57 am
