Post new topic Reply to topic  [ 4 posts ]
PostPosted: Wed Aug 22, 2012 8:06 am
I have a very roadbike akin cyclocross bike. Would it be unrideable if I put a 80-100mm suspension fork on it, to use it for a few leisure MTB rides in summer? Mostly gravel roads of different quality, and easy trails, no hardcore stuff.
Bikes: Raceur, Beateur
PostPosted: Wed Aug 22, 2012 9:12 am
I've been riding what I'd classify as easy trails with my cross bike (standard setup, rigid fork) without any problems. If it's mostly fire roads I think you should be fine.
PostPosted: Wed Aug 22, 2012 9:27 am
The frames geometry will remain the same if the axle to crown height of a suspension fork is the same as the rigid that you have already. This is very unlikely though. Looking at a few, if you are going from a road fork you could be adding as much as 120mm to the fork length, from a cross for more like 90mm. I think this would have a very noticeable effect on the handling of the bike, if you could borrow a fork from someone to try it might be worth it.
But as the poster above mentioned, it's possible to ride a standard cross set up off road with no problems whatsoever!
PostPosted: Wed Aug 22, 2012 9:29 am
Yes, I've been doing lots of MTB with a rigid fork in the 90s, and with a suspension in the early 2000s. I know if I have an MTB(-ish bike) I'll be using it more, also on trails, but probably not enough to justify a whole bike. Riding the winter beater with a flat bar and suspension fork sounds like a budget solution, unless people think it won't work out.
Hmm maybe I could run a 27.5" front wheel to compensate for the added rise, although that might look a bit weird.
Users browsing this forum: No registered users and 9 guests
There are no new unread posts for this topic. lightest 29er suspension fork
in MTB
Dennis
19
3363
Sun Mar 03, 2013 10:12 pm
eme999 View the latest post
There are no new unread posts for this topic. New fork for TI frame
skiezo
19
1033
Sat Mar 30, 2013 5:47 pm
la rosa View the latest post
There are no new unread posts for this topic. FS 29" frame and fork for XC-Racing?
in MTB
rekrej
Wed Jul 11, 2012 6:41 am
socratease View the latest post
There are no new unread posts for this topic. Attachment(s) Colnago C59 Di2 Frame/Fork !!SOLD!!
kx_1
Sun Mar 17, 2013 7:55 pm
kx_1 View the latest post
There are no new unread posts for this topic. Buying a CAAD 10 frame/fork?
jjones
13
1271
Thu Jan 24, 2013 3:55 pm
yourdaguy View the latest post
It is currently Sat May 25, 2013 7:51 pm
