Post new topic Reply to topic  [ 2 posts ]
PostPosted: Tue Aug 07, 2012 9:49 am
I need some help with the following:
I'm trying to put a 40t outer chainring on a 44t-32t-22t 3x9 XT crank. However this doesn't work because the front derailleur plate is hitting the middle chainring when shifting to the outer chainring. Thus, the tooth difference between the outer and middle chainring is too small.
Does anybody know a good way to solve this? Is there any front derailleur that will accept this smaller difference?
PostPosted: Tue Aug 07, 2012 8:47 pm
Just set the front derailleur so it will clear the middle ring?!
(ie. move the derailleur up about 5-10mm.)
You will have more than the normal 2-3mm of clearance between the big ring and the outer plate of the front derailleur (something more like 7-13mm) but as long as you set your outer limit screw well it will shift well enough and you shouldn't have any major problems with overshifting.
I don't think you'll find any derailleur that you handle such a small difference in chainrings any better.
Good luck.
Let us know how it turns out.
Users browsing this forum: yourdaguy and 9 guests
There are no new unread posts for this topic. Mr. Derailleur
Geoff
12
1159
Wed Dec 05, 2012 11:17 am
BobSantini View the latest post
There are no new unread posts for this topic. Is this the end of the front derailleur?
SWijland
23
2004
Sun Dec 23, 2012 2:05 pm
Franklin View the latest post
There are no new unread posts for this topic. Nin Schurter with new or old derailleur?
in MTB
Mads Kock
13
1094
Tue Jul 03, 2012 5:27 pm
jooo View the latest post
There are no new unread posts for this topic. Frm front derailleur
in MTB
Dennis
Sat Dec 22, 2012 7:40 pm
Dennis View the latest post
There are no new unread posts for this topic. Red derailleur problem
Roeboe
16
772
Mon Oct 29, 2012 6:05 pm
Roeboe View the latest post
It is currently Wed May 22, 2013 4:33 am
