Post new topic Reply to topic  [ 14 posts ]
PostPosted: Fri Jul 13, 2012 9:42 am
I want something that can handle 60psi for riding the to trails. Alloy 29er and easy to run tubeless.
The ZTR 29er's are apparently flexy as. Stan's Arch 29er a better option?
FRM 333 don't advise going over 40psi
What are peoples fav functional 29er rime.
Cheers.
My YT channel
http://www.youtube.com/user/durianriders?feature=mhee" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Follow me on Strava
http://app.strava.com/athletes/254600
 Post subject: Re: BEST alloy 29ER RIM
PostPosted: Fri Jul 13, 2012 10:26 am
Frm xmd333 888 strong very light and sexy ive tried hard with mine i carnt brake em just fast xc tho :lol:
PostPosted: Fri Jul 13, 2012 1:10 pm
Stans Podium followed by the FRM388 and Crest are the lightest alloy rims. Note: I don't have any links of pics, but have heard that the FRM actual weight is closer to 350g - as opposed to the 333g claimed.
Stans are also quite clear to state the the Podium is not meant to be anything other than a race rim with a short life span - ring them if you don't believe me :D
I use the Crest only because I cannot source the FRM's in Oz.
Norwood & Adelaide Uni CC
PostPosted: Fri Jul 13, 2012 1:53 pm
I would vote Crest, except if you are running tubeless, they don't recommend over 40 psi on their rims on any decent size MTB tire.
PostPosted: Fri Jul 13, 2012 8:55 pm
I don't find crests to be too flexy for rough xc use.
60psi is a ton though!
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Fri Jul 13, 2012 9:38 pm
I have no experience of these yet, but both might be worth of testing:
e.thirteen TRS+
WTB Frequency i19
PostPosted: Fri Jul 13, 2012 9:39 pm
Yeah I agree. 40 psi will get you to the trail just fine. Then you can drop them to the low 20s and enjoy the smooth ride.
PostPosted: Sat Jul 14, 2012 9:03 am
the FRM 333 to narrow, like a road rim
PostPosted: Sat Jul 14, 2012 11:27 am
The narrow frm,s give a lovely rounded profile to the tyre and not road rim thin ? It makes them very fast! Why have a fast wheel and use it for trials? Also the urano team wheel set with the xmd333 will take 3.5bar! Ive seen bent stans, crests etc no psi and too shallow side wall not for me at all ive only converted about 6 chaps si far lol its my mission all the pics of mine up close are on ebay on the salsa fargo ti 29er full bike under 17lb :thumbup:
PostPosted: Sat Jul 14, 2012 1:13 pm
Racers are obsessed with 29ers and we’ve unleashed the world’s fastest, most advanced 29er cross-country race wheels. Bill Shook designed this breakthrough tubeless race wheel system emphasizing strength, durability and stiffness in a concept Bill calls, “multiplying lightness.” The 29” rim is a whopping 28mm wide x 22mm
deep and only 340 grams. Ride smaller, lighter tires because they spread out across the wide rim without sacrificing traction and handling. The tire does not float around on our wide rim. Bead barb
technology hooks on the tire bead to secure the tires in place without burping. New lighter 14/16 AC Race Round spokes were specially engineered for this hand built wheel system. Dominating at
the races this season, our testers prized their speed, quick accelerations, decisive cornering, nimble climbing, speedy descents, and low maintenance. When seconds count in the relentless pursuit to win, our MTB Race 29 Tubeless wheels deliver the ultimate technological advantage.
PostPosted: Sat Jul 14, 2012 10:00 pm
America classic err ow dear someones got to believe the hype and buy them lol the hubs are good but the spoked are like solder wire and rims plastercine 8) but if your on a tight budget then you will not find lighter from a factory wheel just dont go all mountain on them stick to the xc thay intended!
PostPosted: Sun Jul 15, 2012 5:27 am
I'm a big fan of the Crest. They build up pretty rigid and are easy to setup tubeless.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Sun Jul 15, 2012 6:02 am
http://www.bikerumor.com/2012/07/12/bik ... more-45952
PostPosted: Mon Jul 16, 2012 10:04 am
I should add I wan't clincher, am 65kg and enjoy durability as well.
My YT channel
Follow me on Strava
Users browsing this forum: Google Adsense [Bot] and 9 guests
There are no new unread posts for this topic. making my 29er handle faster
in MTB
devinci
26
2204
Mon Dec 10, 2012 3:05 am
DLEVETT View the latest post
This topic is locked, you cannot edit posts or make further replies. alloy road clincher rim? stiff yet light?
durianrider
Mon Jul 16, 2012 10:16 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. 2012 Cannondale Scalpel 29er Alloy 3 Full Suspension Bikes..
record
Mon Jul 30, 2012 2:19 pm
michel2 View the latest post
There are no new unread posts for this topic. Ax Lightness Handle / Stem
wshiong
Sat Apr 20, 2013 9:58 am
wshiong View the latest post
wshiong
Wed Apr 10, 2013 2:26 am
It is currently Sun May 26, 2013 6:54 am
