Post new topic Reply to topic  [ 12 posts ]
PostPosted: Tue Jul 03, 2012 4:43 pm
I broke my KMC10sl chain. I believe the reason why it broke is because I had to remove it, and I used a chain tool instead of unhooking the Q link. How do you unhook the q link? Thats the way to remove the chain it seems.
Scott Spark LTD 8.40kg
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
PostPosted: Tue Jul 03, 2012 5:05 pm
I've never had much luck repinning X10 chains. I have broken several.
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Tue Jul 03, 2012 5:11 pm
Kind of tricky - the hard part is getting needlenose pliers that will allow you to compress the link at the master. You also have to squeeze the link with your fingers on the flat section to unlock it and then use the pliers to bring the together. It's a little bit of a pain, they actually make some pliers that hug the link while you press with your fingers. Sorry, it's kind of hard to explain without pictures.
edit - just saw the pictures, knock out that bad link with your chain tool and re-attach it with another missing link, you should be good to go.
PostPosted: Tue Jul 03, 2012 5:12 pm
It's very easy :D :
http://www.youtube.com/watch?v=eEHrWId8kvg" onclick="window.open(this.href);return false;
PostPosted: Tue Jul 03, 2012 6:06 pm
I made a tool from a 5" mole grip pliers
I ground the sides down enough to fit between the side plates, then ground a grove in each nose to allow it to grip round the rollers
They work great on 10 speed i`ve not tried them on 11s yet but I cant see why not
Barrie
PostPosted: Tue Jul 03, 2012 7:03 pm
I have never needed any tools for the quick link. Just squeeze the links, give them a wiggle and push them together lengthwise. It is easier if the chain is clean, but should not have a problem.
TIME RXR
PostPosted: Tue Jul 03, 2012 7:19 pm
Im also using quick links and I have not had problems just using my hands. I normally remove tension from the chain (do it when i have the backwheel of or drop the chain of the front). It also helps if the link is clean. Then just kinda push both on the link next to the q link. Just pay attention to the part of the q link that moves toward your hands
Parlee Z5 ML
PostPosted: Tue Jul 03, 2012 9:21 pm
I use a piar of nail pincers; fold the chain so the jaws of the pincers can press on the rollers and squeeze, a bit fiddly but works.
Read somewhere that the reomveable link should be installed always so the fixed end is pointing in the direction of travel on the inner side of thain i.e. as it would rub agaisnt the cassette.
nail pincers:
PostPosted: Wed Jul 04, 2012 11:21 am
http://www.parktool.com/product/master-link-pliers-mlp-1
PostPosted: Thu Jul 05, 2012 4:48 am
+1 on the Park Tool, see above.
I've only had one KMC X10SL that I could open / unlatch by hand. A half dozen later, I don't even bother trying and stick to my Park Tool.
Enjoy
My sub-5.7kg / 12.53lb Addict R1
WTB: Challenge latex tubes, 700c x 60mm - NEW only
PostPosted: Sun Aug 05, 2012 5:03 pm
my version.
£ 1 for pliers from Poundland and 15 mins with grinder. ..... and it works!!! :thumbup:
PostPosted: Tue Aug 07, 2012 8:55 pm
Just gotta have a soft touch :)
I use 9sp and 10sp links on several bikes and can always open and close them by hand. Just release a bit of tension and sweet talk them apart (ie. lightly push together from the side of the plates with the pin fixed to them. That is, if each part of the replaceable link is an 'L', push from the corner of the 'L' to the corner of the other 'L'. If it is hard you are doing something wrong.)
Users browsing this forum: Google [Bot] and 8 guests
There are no new unread posts for this topic. My Time stem screw broke. Help!
phourgenres
Thu Apr 18, 2013 1:47 pm
Tenlegs View the latest post
There are no new unread posts for this topic. R5CA collar/clamp broke
perullo
13
1385
Wed Oct 03, 2012 5:54 pm
perullo View the latest post
There are no new unread posts for this topic. chain drop on SRAM chain catcher
PoorCyclist
Fri May 10, 2013 4:38 am
timzcat View the latest post
There are no new unread posts for this topic. Yaw shifting with KMC chain vs 1091R chain
rijndael
Fri May 10, 2013 2:49 am
DaleRider View the latest post
There are no new unread posts for this topic. DIY chain holder
Bianchi10
9
808
Tue Apr 30, 2013 6:11 pm
User Name View the latest post
It is currently Sat May 25, 2013 12:08 am
