Post new topic Reply to topic  [ 8 posts ]
PostPosted: Sun Jul 01, 2012 10:52 pm
Anyone have experience with using XTR calipers and XX master cylinder?
Highline Search Group | http://www.highlinesearch.com | Outdoor & Sporting Goods Recruiters
PostPosted: Sun Jul 01, 2012 11:54 pm
Don't see that working out well for you....
Shimano are designed for use with mineral oil and Avid use DOT brake fluid. Those two systems are not typically compatible.
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Mon Jul 02, 2012 12:37 am
What crohnsy said. The DOT fluid will eat up the Shimano seals very fast, worst case fall apart when you need them the most. I highly reccomend you not to do this.
WTB: MTB hubs, 29'er carbon rims
My 7.3kg/6.4 kg 29'er project buildthread!
My Bianchi Oltre XR
PostPosted: Mon Jul 02, 2012 4:36 am
Another vote against it. Don't mix and match brake systems. Never a good idea.
PostPosted: Fri Jul 06, 2012 1:51 am
All valid points and makes sense. I want XX shifter and XTR brakes and integrated on the bars. Will keep wishing..
PostPosted: Fri Jul 06, 2012 3:13 am
custom mount, that's what you need. shouldnt be that hard. find someone with a small mill or one of those new-fangled desktop 3d printers (i got one coming, cant wait!)
PostPosted: Mon Jul 09, 2012 10:26 pm
new fangled 3d printer. I was using one over 10 years ago. Hardly new!
www.thecycleclinic.co.uk
PostPosted: Tue Jul 10, 2012 3:52 am
new-fangled=desktop, $600. i'd wager that one ten years ago was a bit bigger, bulkier, much more expensive.
Users browsing this forum: No registered users and 11 guests
There are no new unread posts for this topic. Attachment(s) "De-Paired" hub
monkeyburger
Sun May 27, 2012 12:54 am
monkeyburger View the latest post
There are no new unread posts for this topic. Extending caliper reach?
WeightySteve
11
410
Fri Jul 20, 2012 1:44 am
There are no new unread posts for this topic. lightest disc caliper
cymans
11
2049
Fri Jul 20, 2012 3:06 pm
bones View the latest post
There are no new unread posts for this topic. DA rear caliper on the front?
wassertreter
Sat Sep 08, 2012 4:53 am
oysters View the latest post
There are no new unread posts for this topic. Zero G Negative G rear brake caliper £75
jonjones13
Thu Mar 14, 2013 12:37 pm
jonjones13 View the latest post
It is currently Sat May 25, 2013 3:06 pm
