Post new topic Reply to topic  [ 11 posts ]
PostPosted: Wed Jun 27, 2012 3:16 pm
Anyone had this issue, I cannot get one out for love nor money.
Should I put a tiny amount of grease on the Ti bolt to prevent this in the future?
"I could have done this job myself in five minutes, but as things turned out I had to spend two days trying to find out why it had taken someone else three weeks to do it wrong."
PostPosted: Wed Jun 27, 2012 3:55 pm
try soaking it a couple of times in ammonia. also try "scaring" the bolt by tapping it. You could also try to heat up the hub a little as TI and Al will expand at different rates.
That's about all I can think of.
    2011 Cannondale Flash F1
      2010 Cannondale Caad9
        2000 Cannondale Caad 4 aero
          1999 Cannondale Caad1
            ???? Concorde SS
PostPosted: Wed Jun 27, 2012 4:02 pm
In the future you should use some copper anti seize. Grease will not work well in this situation.
Good luck they will be difficult to remove!
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Wed Jun 27, 2012 8:44 pm
Tried heat to no avail, its bent my torq bit as well,
The disc may have to stya on forever!!!!
Dont fancy trying to drill that bolt!
PostPosted: Wed Jun 27, 2012 9:13 pm
Had a stuck rotor bolt in my rear pro II. Managed to drill it out without damaging the hub. Is this an option with titanium?
PostPosted: Thu Jun 28, 2012 2:08 am
You could try removing the other 5 bolts. Have one person trying to loosen the torx bolt and have a 2nd person with two hands on the rotor turning it counter clockwise.
PostPosted: Thu Jun 28, 2012 7:56 am
:smartass: Yes, just remove the other bolts if you can and turn the rotor counterclockwise, it will also loosen the last bolt. This has happened to me last week and it worked.
PostPosted: Thu Jun 28, 2012 7:07 pm
Take a soldering iron and put the tip to the head of the titanium bolt. This will locally heat the Ti bolt without cooking your hub.
Then try the rotating rotor trick. Or if you have mangled the head too much to get a torx bit on, you can then try a left hand drill bit and start drilling the bolt out. Else cut a slit and use a flat head screw driver bit on a ratchet and see if you can undo it then.
For Ti rotor bolts, use loctite 243 or loctite 222 + loctite 7471 primer. The locitte will prevent galvanic corrosion and act as a secondary locking feature to prevent loosening. Remember to always torque to the recommend value. I prefer loctite over antiseize in this application.
Reason for loctite over antiseize.
http://www.hackracer.com/2012/03/part-2 ... ocker.html
http://www.hackracer.com/2012/02/part-1 ... icals.html
PostPosted: Fri Jun 29, 2012 7:38 am
http://www.hackracer.com/2012/03/part-2 ... ocker.html" onclick="window.open(this.href);return false;
http://www.hackracer.com/2012/02/part-1 ... icals.html" onclick="window.open(this.href);return false;
:thumbup:
PostPosted: Mon Jul 09, 2012 8:34 am
The rotor spinning trick is a good one.
You can also rig up a torx head to a hand impact driver--these work excellent for types of things you think you'll have to drill. Use penetrating oil beforehand, as well as heat to break the loc-tite, if any remains.
PostPosted: Mon Jul 09, 2012 2:26 pm
I was kind of hoping these links were more than just your personal blogspam.
It is great you are an aerospace engineer and you can find similarities between your work and your hobby, work in a bike shop for a season and you will find uses for red Loctite
Flickr
Follow on Instagram
Users browsing this forum: Bing [Bot] and 11 guests
There are no new unread posts for this topic. Aluminium bolts, where to buy??
in MTB
adidavas
12
1211
Sat Mar 30, 2013 8:20 pm
sow View the latest post
There are no new unread posts for this topic. 30mm 18h aluminium rim
Rob81
Sun Feb 17, 2013 9:21 pm
GonaSovereign View the latest post
There are no new unread posts for this topic. 33 mm 20 h aluminium rim on the market ?
LouisN
Fri Feb 15, 2013 9:44 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Polishing an aluminium stem
GASer
12
797
Sun Nov 11, 2012 11:26 am
User Name View the latest post
There are no new unread posts for this topic. 32h aluminium tubular rims?
in Cyclocross / Touring
the_marsbar
12
1394
Thu Aug 09, 2012 5:11 am
mtbwrx View the latest post
It is currently Sat May 25, 2013 7:54 am
