Post new topic Reply to topic  [ 24 posts ]
Go to page Previous  1, 2
PostPosted: Thu Jun 28, 2012 9:13 am
I thought that the Supersonic version was the wide version, and maybe only the older tires? I had a pair myself, but they didn't work out for me tubeless. If the Racesport version is as wide as the "old" Supersonic I'd gladly get another pair.
PostPosted: Thu Jun 28, 2012 11:45 am
The Racesport is as wide as Supersonic on the RaceKing 2.2. As for the tubeless here is what has always worked for me:
1. Scrub the inside of the tyre with Isopropyl Alcohol
2. Mount and inflate the tyre with 90g of Stans
3. Shake it, add more air and take it out for a ride around the block
4. Dismount the wheel, shake it more, and add more air if needed.
5. Repeat point 3 and 4 until no more leaks.
The above has worked for me 100% of the time, on the second ride the tyre looses very little air - like 0.1 bar. The key for me is the ride around the block.
PostPosted: Thu Jun 28, 2012 3:21 pm
Normally that works for me as well, but it didn't with RK SS. I might have a go at the Racesport version though...
PostPosted: Thu Jun 28, 2012 6:51 pm
A tire that is 2.4" in width will have less resistance than a 2.2" tire?
Scott Spark LTD 8.40kg
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
PostPosted: Thu Jun 28, 2012 7:49 pm
Yes, especially with lower pressure. Schwalbe made a scientific about rolling resistance on different trail surface for tyres with different width and pressure. The conclusion was that on anything but tarmac, lower pressure and wider tyres have the lowest rolling resistance.
PostPosted: Thu Jun 28, 2012 8:34 pm
I just orderd the Raceking supersonic 2.2". I got them for $116 pair. Hopefully they are the supersonic version when they arrive.
Giant NRS (Retired)
PostPosted: Fri Jun 29, 2012 12:06 am
I weigh 170lbs. What do you suggest my psi be on my Continental Race King Supersonics when I put them on?
Giant NRS (Retired)
PostPosted: Fri Jun 29, 2012 5:06 am
Are you running them tubeless? If yes, I would start at 1.8bar rear and 1.6bar front. If running tubes, may be a bit higher.
PostPosted: Fri Jun 29, 2012 6:44 am
non tubeless
Giant NRS (Retired)
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Users browsing this forum: No registered users and 7 guests
There are no new unread posts for this topic. Which wheels will make me faster?
bruno2000
13
1385
Sat Aug 04, 2012 11:02 am
g_doraz View the latest post
There are no new unread posts for this topic. Well I have to admit Cancellara was faster than me...
el condor
7
1264
Sun Jun 24, 2012 1:18 pm
Kasparz View the latest post
There are no new unread posts for this topic. making my 29er handle faster
in MTB
devinci
26
2244
Mon Dec 10, 2012 3:05 am
DLEVETT View the latest post
There are no new unread posts for this topic. For the experienced riders: Is stiffer faster?
dvincere
34
1867
Thu Feb 07, 2013 8:13 am
tosterbe View the latest post
There are no new unread posts for this topic. XX light 2.35 OR 2.10 innertubes in a 2.40 Rocket Ron
in MTB
ArferBar
Fri Feb 15, 2013 8:34 pm
DanW View the latest post
It is currently Wed Jun 19, 2013 4:57 am
