Post new topic Reply to topic  [ 3 posts ]
 Post subject: BB91 and 2,5mm spacer
PostPosted: Sun Jun 17, 2012 10:35 am
Frame is Scott Scale 30 and its bb shell is 89,5mm wide. Shimano teh doc syas that with this width I have to use 2,5mm spacer between bb cup and frame. I removed the old bb and there wasn´t this spacer. Do I have to use it with new bb? Everything worked fine exept left bearing got stuck(rusty).
"Nothing compares to the simple pleasure of a bike ride"
Scale 30
Schenk 007
My blog
PostPosted: Tue Jun 19, 2012 10:22 pm
If your old crankset was the same make and model, then you probably do not need the spacer b/c you would have noticed difficulty while shifting. Therefore, if your Shimano crankset and BB are different, then you should consult the Scott manual.
PostPosted: Wed Jun 20, 2012 6:43 am
I only replaced the BB and did not put this spacer. Just don´t understand, why Shima says it should be there.
Scale 30
Schenk 007
My blog
Users browsing this forum: AndrewL and 10 guests
There are no new unread posts for this topic. Shimano BB91 BB and slow spinning / sitcky crankset
drewb
Wed Aug 22, 2012 9:12 am
Omiar View the latest post
There are no new unread posts for this topic. BB92 pressfit BB + spacer?
in MTB
Mads Kock
Sun May 19, 2013 1:53 pm
Mads Kock View the latest post
There are no new unread posts for this topic. Cdale Evo conical spacer
in Wanted
Bianchi10
Sun Mar 10, 2013 2:53 pm
Bianchi10 View the latest post
There are no new unread posts for this topic. FSA headset zero stack cone spacer
Fri Feb 08, 2013 11:02 pm
113245 View the latest post
There are no new unread posts for this topic. Looking for white tapered headset spacer
iscarrr
Mon Oct 01, 2012 6:49 am
iscarrr View the latest post
It is currently Fri May 24, 2013 6:36 am
