Post new topic Reply to topic  [ 13 posts ]
PostPosted: Mon Jun 11, 2012 4:23 pm
My MTB is currently weighing in at just over 11Kg (11.5Kg with pedals), I'm aiming to get it down to sub 10Kg, as I know the weight of everything on the bike I'm trying to get some weights for a typical 'just under 10Kg' bike so I can understand
1/ What I have that I probably don't need to change
2/ If i do have to change something, what weight to aim at in order to use whatever I spend most effectively (no point spending twice as much say on a stem when I could get '10Kg capable' basr as well as an example.
So having looked (honest!) I can't find any suitable threads (lightbike would have been perfect!), anyone know of one?
PostPosted: Mon Jun 11, 2012 5:57 pm
My 2012 Specialized Epic S-works 29er is 10.55 in everyday format (with training wheels and heavy PG1070 cassette). I run real pedals too- XTR 980.
Bike is stock with the following exceptions.
Bars- changed to Salsa Pro Moto Carbon
Stem- changed to older Ritchey WCS
Seatpost- changed to Momsen design layback
Saddle- Changed to Romin Pro carbon rail
Cranks- changed to Rotor 3D+
Carbon-Ti - front skewer
ESI grips
Also put some heavier stuff on as it is a daily driver- not a showpiece.
Stan's wheels with Crest rims and 330 hubs (stock model)
SRAM PG1070 steel cassette.
Avid clean sweep rotors (not the fancy ones)
Schwable Racing Ralph 2.25 Snakeskin rear/2.35 lighter one up front
PostPosted: Mon Jun 11, 2012 8:56 pm
Thanks, but not really giving me the weight breakdown I need....
PostPosted: Mon Jun 11, 2012 11:07 pm
One list of components and weights may not give you the best idea. You can post the components you currently have on your bike and get suggestions on how to make it lighter.
Chris.
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Tue Jun 12, 2012 6:19 am
viewtopic.php?f=1&t=103565"
Bike: 2012 Boardman HT Pro MTB - 21.949lbs / 9.956kg (for now...)
PostPosted: Tue Jun 12, 2012 8:25 am
Krys, I do realize that, but it's a start! The more the merrier.
Thanks Chuck, seen and posted on that thread, but again no breakdown!
Here's my weights...
Frame
Carrera Kraken Bare Frame (painted Ford met' purple) 1742
Frame blanking bolts 2
Rear derailleur hanger plus bolts 17
Plastic under BB cable guide plus bolt 4
Drivetrain
Deore HT2 BB 99
Inner chainwheel retaining bolts 11
outer chainwheel retaining bolts 19
Ally GT bash ring 82
Deore HT2 RH arm 387
Deore HT2 LH arm 263
Deore preload adjuster 4
36T Middle ring 58
Small ring 40
Ritchey SPD pedals 350
Deore low mount front mech 129
Front X7 shifter 124
Front Cable outer 10
Front cable inner 17
Rear Rocket shifter 128
Rear cable front outer 10
Rear cable inner 10
Rear cable rear outer 7
Deore XT rear mech 226
Chain 257
Brakes
Avid Juicy 5 front 305
front calliper bolts 7
Avid Juicy 5 rear (est) 325
rear caliper mount and bolts 46
Seat
Promax carbon seatpost 234
GT QR seat clamp 43
Charge Spoon saddle 293
Steering
FSA Cartridge headset bearing 117
Manitou Skareb Elite forks 1486
Star fangled nut 10
Top cap and bolt 15
Superstar 80mm stem with bikehut faceplate 122
Bikehut 31.8 Carbon 167
Imperial (pale Blue) Grips 80
Carbon Headset spacers 21
Wheels and tyre
Mavic Crossride 916
160mm Tektro 101
Bolts 12
Tube 125
Panracer Fire XC 2.1 720
Shimano XT QR skewer 58
Mavic Crossride 1073
Shimano M760 Cassette 296
Cassette spacer 4
Hayes rear disc 112
Bolts 11
Schwalbe Tube 125
Panaracer Fire XC 1.8 Wired 620
Shimano QR skewer 74
I know the wheels are a bit heavy, as are this years winter tyres, folders next year (I already have some folders for summer) and there is 450g ish to be had there.....this is also a 'daily rider' so QR seatpost clamp and robust (Shimano are that) Skewers are a must.
PostPosted: Tue Jun 12, 2012 12:18 pm
My Scale is listed out with an Excel breakdown of weights, and its just under 20 Ib's:
viewtopic.php?f=1&t=103650#p884546
Scott CR1 - 12.84Ib
PostPosted: Tue Jun 12, 2012 12:32 pm
Steve,
Thanks, that's perfect, I'll have to transpose that onto my excel spreadsheet for comparison!
Simon
EDIT Done, some interesting info in there Steve thanks.....
PostPosted: Fri Jun 15, 2012 7:53 am
Steve,
Thanks again for a look at that spreadsheet, nice bike, good to see a lot of my components are competative, in fact just frame and tyres would have the difference to yours although your frame is exceptionally light!
PostPosted: Fri Jun 15, 2012 4:09 pm
Check out some of the threads on the WW section over on mtbr.com There are quite a few quality threads over there with parts lists/weights posted.
09 Pinella w/ Record 10spd
http://1spd.blogspot.com/
PostPosted: Fri Jun 15, 2012 11:07 pm
Here's mine.
https://docs.google.com/spreadsheet/ccc ... VM0WUZkc1E
Grover's Grumblings
Grover's Garage
PostPosted: Sat Jun 16, 2012 7:39 am
Thanks for that Grover, very helpful.....very different numbers to Steve's for a similar weight bike.....I can now start averaging as well which is a big help!
PostPosted: Sun Jun 17, 2012 9:10 am
http://www.weightweenies.com.br/blog/?page_id=17
Users browsing this forum: No registered users and 14 guests
There are no new unread posts for this topic. Attachment(s) typical wheel weight breakdown
in MTB
02GF74
Sun Dec 30, 2012 12:17 pm
campbellrae View the latest post
There are no new unread posts for this topic. The NEW Weight Weenie Kit Thread
[ Go to page: 1 ... 9, 10, 11 ]
Szczuldo
155
5659
Fri May 24, 2013 7:10 pm
KvnP View the latest post
There are no new unread posts for this topic. Attachment(s) your bikes cost breakdown
Dozer
24
1807
Fri Oct 12, 2012 6:23 am
shimmeD View the latest post
There are no new unread posts for this topic. Specialized Rockhopper 2011 - Project 10kg
SimonGoesSideways
7
1906
Thu Nov 15, 2012 8:49 pm
hillrider View the latest post
There are no new unread posts for this topic. Advice for a full aluminum full suspension 29'er
in MTB
tomp
Tue Sep 11, 2012 9:32 pm
neiloxford View the latest post
It is currently Sat May 25, 2013 7:35 pm
