Post new topic Reply to topic  [ 12 posts ]
 Post subject: Seat post...
PostPosted: Wed May 30, 2012 11:39 am
Hi All,
Brand new to the site so go easy!!
I really want to pimp the bike up a little and want to start with a seat post. I know of the KCNC Ti Pro Lite Scadium, but wondered what you would advise I should look at?
The bike is a Cannondale Rush so needs to be 27.2 x say 330-350 (no more).
Any advice would be appreciated.
Thanks in advance
:D
 Post subject: Re: Seat post...
PostPosted: Thu May 31, 2012 3:15 am
Rotor - sorta light, not too expensive, nice clamp, unusual but available at most stores.
New Ultimate - Light, expensive, not so easy to buy, not so great clamp?
MCFK - Crazy light, crazy expensive, hard to find, clamp?
Thomson Masterpiece - sorta light (upgradeable), not expensive as is, good clamp, buy anywhere you like.
Easton EC90 - Sorta light, find on sale online, ok clamp, available everywhere.
PostPosted: Thu May 31, 2012 4:31 am
Syntace have a couple also. Not the lightest but a great clamping system, on par with Thomson IMO.
PostPosted: Thu May 31, 2012 4:42 am
Yup. Syntace makes nice stuff. You can get aluminum (P6) or full carbon (HiFlex) that's designed to flex a little. Both are nice.
PostPosted: Thu May 31, 2012 5:19 am
KCNC Ti Pro Lite. Affordable & light.
Please visit my blogs:-
I'm a MILF - er blog (Help raise awareness!) http://firespitter38.blogspot.com
True tales from the dark side http://truetalesfromthedarkside.blogspot.com
PostPosted: Thu May 31, 2012 10:14 am
In my own experience trying about half the posts mentioned, I've been happiest with Syntace and Thomson for MTB. The EC90 I have now creaks, as have the ones I've used with KCNC/MCFK style clamping. Love KCNC posts for road or 'cross, just not MTB.
PostPosted: Thu May 31, 2012 2:41 pm
Hi, i have kcnc ti pro lite on my Grand canyon f8. it is 27.2-400mm long and it weights 151gr ,two years of hard racing and it is still good as new, my recommendation
PostPosted: Thu May 31, 2012 10:07 pm
I'd go with the Syntace P6 Hiflex over a masterpiece.
PostPosted: Thu May 31, 2012 11:02 pm
Token seatpost , I cut my down and its under 100grms . I put a little bit of clear coat where I clamp so its a tight fit and it works fine
PostPosted: Fri Jun 01, 2012 1:44 am
Just curious, why?
PostPosted: Fri Jun 15, 2012 3:07 pm
So what did you go with? I have had two different KCNC's with no problems. My current one is a 27.2 x 400 and it is up to about 1.5cm from the minimum insertion line. Still rolling strong and it is on a rigid ss bike! Couldn't be happier. For the weight/price you won't find much else close to it. Yes, there are lighter posts but they are very expensive. The Thompson is nice and in my mind is the go to post but it is fairly heavy and while upgradeable, you won't be dropping enough weight to come in at the weight of the KCNC and after doing all those upgrades you would have spent more money than some of the other posts costs (Syntace, KCNC...). But the Thompson post should last you forever! Then again, you'll also look like everyone else out on the trail.
09 Pinella w/ Record 10spd
http://1spd.blogspot.com/
PostPosted: Mon Jun 18, 2012 6:36 am
I would have to throw in a vote for the Thompson Masterpiece. It isn't the lightest out there by any means, but I like the clamp and the texture of the post really helps to make it not slip. I like mine to have a slight layback as well.
http://www.zencyclery.com
http://www.wheelbuilder.org
Users browsing this forum: No registered users and 10 guests
There are no new unread posts for this topic. Attachment(s) PMP Seat Post Topper
Snicks
Tue Feb 12, 2013 11:14 am
Snicks View the latest post
This topic is locked, you cannot edit posts or make further replies. Seat post recommendations
Penthousepete
Sat May 04, 2013 5:25 am
cyclistcong View the latest post
There are no new unread posts for this topic. Shorten seat post...?
Juggler
Thu Nov 01, 2012 4:28 pm
Juggler View the latest post
There are no new unread posts for this topic. Bontrager XXX seat post
in MTB
02GF74
Mon Jan 21, 2013 7:42 am
Fisherfreerider View the latest post
There are no new unread posts for this topic. Seat Post Shims - Good, Bad? -
mellowJohnny
21
1417
Sat Sep 29, 2012 3:05 am
mellowJohnny View the latest post
It is currently Tue May 21, 2013 6:18 pm
Ritchey fork, seatpost & stem at cheap prices - starbike.com
