Post new topic Reply to topic  [ 70 posts ]
Go to page 1, 2, 3, 4, 5  Next
 Post subject: New SRAM 1x11
PostPosted: Sat May 26, 2012 6:27 am
I'm probably going blind but I haven't seen this posted here yet:
http://www.bikerumor.com/2012/05/25/sram-teases-xx1-drivetrain-top-level-1x11-w-super-wide-cassette-range-more/
 Post subject: Re: New SRAM 1x11
PostPosted: Sat May 26, 2012 1:50 pm
Hmm, I have enough issues with the current thin 10sp chains bending like spaghetti under pressure. The move to single ring is interesting as the vast majority of pro riders acknowledge that having two rings help conserve energy.
Norwood & Adelaide Uni CC
PostPosted: Wed May 30, 2012 9:24 am
SRAM doing it doesn't move me at all either. I'm still upset that their XX cassette's "replaceable" big cog is no where to be found, when mine needs replacement, since it's skipping under torque on climbs.
Off-topic, that article only supported my impression that BikeRumor is a 2nd rate source of info at best. Their user comments are worse than Pinkbike's as well (which is where they seem to have copied the info from) See bikeradar's for more in-depth coverage: http://www.bikeradar.com/mtb/news/artic ... -11-34098/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Wed May 30, 2012 1:09 pm
well, not sure how long lasting that stuff is, but at least interesting from pure XC race perspective. i personally shifted to 38 in front and 11-36 in the rear recently, and now I can stay on big ring 95% of the time. Bringing in even a bigger cassete would eliminate small cog requirment as such. But... 38 is already not qute enough on the road & easy downhills, and also 10 teeth rear will be SO unefficient due to high friction, that practical applicaiton of 1*11 IMO will be very limited to pure XC rigs only.
PS what's the weight of that 11 cog cassette with huge 40-teeth pan? :lol:
weight concerned = good, weight obsessed = bad!
PostPosted: Wed May 30, 2012 5:22 pm
i thought the implication in the pinkbike article was that this was aimed at enduro racers, not xc?
PostPosted: Wed May 30, 2012 8:34 pm
well, i'm very skeptical. i've finished quite a number of enduros including cape epics & alike, and if you're an average amature rider than such events do require eeeeeasy gears, so that IMO even 2*10 is on the limit. 1*11 is just a no go there, IMO
PostPosted: Thu May 31, 2012 4:23 am
Are you both thinking of different definitions for 'enduro'?
PostPosted: Thu May 31, 2012 11:50 am
cape epic = 4-7h/day * 8 days in the saddle = enduro for me. no? :)
PostPosted: Thu May 31, 2012 3:48 pm
Sandal, I definitely agree that is an enduro of sorts but in this case the term is referring to trail bikes along these lines:
PostPosted: Thu May 31, 2012 6:09 pm
200-300 grams lighter than 2x10 XX? :shock:
PostPosted: Thu May 31, 2012 6:47 pm
I have a hard time believing the 200-300g lighter claims. You lose one super light shifter, one super light front derailleur, a really light chainring and bolts, and then what? 40-50g of cable and housing? But then what about the weight of the new cassette? That thing's massive, it has to add quite a bit of weight!
PostPosted: Thu May 31, 2012 7:20 pm
well, regardless of what we think about it, they wouldn't be investing the time/money in developing it if they didn't think there was a market for it (or that they could creat a market for it).
PostPosted: Thu May 31, 2012 7:33 pm
X2
PostPosted: Fri Jun 01, 2012 10:44 am
xc71 wrote:
X2
I don't:
Front Derailleur - XTR 2x10: 120
Shifter: 80
26t Chainring/bolts: 40 (could be off here)
Cable 45
Total lost: 285
Gained: 60 (no idea what a 36 or 38t cog weighs, i'm being generous I think)
Total Lost: 225.
PostPosted: Fri Jun 01, 2012 9:54 pm
But they can't just add a giant 42t cog, the have to make all of the cogs bigger, including the steel ones. None the less, you're right, and it should end up around 200g+ savings.
Post new topic Reply to topic  [ 70 posts ]  Go to page 1, 2, 3, 4, 5  Next
Users browsing this forum: No registered users and 7 guests
There are no new unread posts for this topic. SRAM 2013 Rings on non SRAM crank?
itsacarr
Tue Jul 03, 2012 3:48 am
boots2000 View the latest post
There are no new unread posts for this topic. upgrade Sram Red 2011 Brakes to the new Sram Red 2012 brakes
poppiholla
Wed Jul 04, 2012 10:20 am
MarkThailand View the latest post
This topic is locked, you cannot edit posts or make further replies. Sram Red 22
BeeBee30
Sun Apr 14, 2013 1:44 pm
BeeBee30 View the latest post
There are no new unread posts for this topic. Sram Red FD with yaw
jrafter
Thu Aug 09, 2012 5:24 pm
seandonovan View the latest post
There are no new unread posts for this topic. fs sram red fd.
SDP
Thu Mar 14, 2013 7:38 pm
SDP View the latest post
It is currently Sat May 25, 2013 9:40 am
