Post new topic Reply to topic  [ 24 posts ]
Go to page 1, 2  Next
 Post subject: Weight Weenie Epic 29er?
PostPosted: Thu May 24, 2012 6:54 pm
Hi,
Just got a 2012 S-works Epic 29er.
I am interested in making some ww mods.
Wondering what mods that you have made.
I have already changed to a lighter handlebar.
I intend to put a lighter post (Momsen Design) and a carbon rail saddle, also a Ritchey WCS stem.
What else?
Lighter rotors?
What bolts?
Do people use Ti disc caliper bolts?
PostPosted: Fri May 25, 2012 3:11 am
stock post is a pig. i went with a masterpiece with some ti bolts, washers, and barrel nuts. stem is relatively light, though, and a good performer (f109). ti rotor bolts for sure. if you got the sram version, it has the ti bolts already. little things like the brain mounting bolt and brain hose clip bolt are steel, so change those out. change the stock valves out-i used american classics because theyre all aluminum with a removable core and RED! chainrings can help, also look into using lightning's spider as its compatible with the sworks crank but supposedly half the weight.
PostPosted: Fri May 25, 2012 3:48 am
Thanks for the tips. I am using rotor 3d+ cranks- they are lighter than the specialized.
PostPosted: Sat May 26, 2012 6:12 am
A syncros 12mm axle will save you just under 30gms if you have the dt Swiss one
PostPosted: Sat May 26, 2012 6:28 am
They sure aren't. Search
You mean Syntace?
PostPosted: Sun May 27, 2012 8:11 pm
You mean Syntace?[/quote]
Yes syntace
PostPosted: Mon May 28, 2012 12:07 am
Have fun ;)
http://www.mtb-news.de/forum/showthread.php?t=568474
PostPosted: Tue May 29, 2012 7:42 pm
The post is really heavy, as is the stock seat. Everything else is pretty much good. Perhaps the grips, going to ESI will save you about 40g.
I have mine setup 1x10 and love it. With real MTB tires, XTR (ie heavy) pedals, and a bottle cage, it's under 21.4 lbs.
Awesome bikes.
PostPosted: Thu May 31, 2012 7:43 pm
What tires are those? Like them?
How much do you estimate 1x10 saves you? Not that I would do it- I have climbs steep enough that they challenge my 24/36 bottom gear.
So far I switched to a Ritchey WCS stem, Salsa pro moto carbon 11 deg bars, and I am getting a carbon rail Romin saddle and Momsen design layback post.
PostPosted: Fri Jun 01, 2012 3:47 am
Lookin' good indeed. What tire is that in the back?
PostPosted: Fri Jun 01, 2012 3:41 pm
Maxxis Ikon 2.2 in the front and a Specialized S-works Fast Trak 2.0" in the rear.
The one on the picture is actually the older LK S-works tire, as I cut a rear Ikon a few days prior and had this tire sitting around. I've since replaced it with one of the 2012 S-works Fast Trak 2.0" tires with the new tread pattern.
I have a race this weekend and couldn't source another Maxxis Ikon fast enough. So far the Fast Trak has proven pretty nice. It's a bit lower in volume than the Ikon, but rolls a touch faster. Grip has been good on the two rides I've used it on. Racing this weekend on this setup, so I'll let you know how it does.
RE 1x10:
I'm not sure how much it saves.... I do it for reliability and simplicity more than anything else. I simply adjust my froth chain ring according to where I'm riding. Most of the time I leave a 34T on the front (with 11x36 out back). Fast courses I will swap a 36T and if there is a lot of climbing then I go with a 32T. Even in UT and CO, I've been fine with this setup for a few years now. If it were a dedicated trail bike then I'd likely go with a double for a bit lower gearing.
I'm guessing you save about 100g on the shifter, 30g on cable and housing, 40g on chain ring, and a bit more on the front der (some of which you gain back from chain guide).
PostPosted: Sat Jun 02, 2012 11:07 pm
What exact parts are needed to do that Syntace conversion on a 2012 Epic? Have you done it? Does the axle kit come with everything or do I need to order the eccentric threaded part, der hanger, etc?
PostPosted: Sun Jun 03, 2012 8:31 am
You just need the smaller axle. Its available in 2 lengths.
PostPosted: Sun Jun 03, 2012 9:28 am
This is my Large S-Works 29er http://ryansherlock.blogspot.ie/2012/06/2012-specialized-s-works-epic-29er.html
Basically, it is the SRAM Stock version - switched in NoTubes wheels, Schwalbe Tires, KCNC finishing kit (front skewer, grips, bar, stem, post). I am currently using the older Phenom saddle but will probably find something lighter. I have not had it on a very accurate scale but it is approximately 9.8kg ready to race (with cage/pedals/computer).
Nice tip on the Syntace bolt through - thanks!
http://www.ryansherlock.com
PostPosted: Sun Jun 03, 2012 9:20 pm
Easy to make a bike light with eggbeater pedals.
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
Users browsing this forum: socratease and 5 guests
There are no new unread posts for this topic. Attachment(s) My third Venge... and my Epic Evo R 29er.
kakanpolen2
Mon Nov 12, 2012 9:45 am
kakanpolen2 View the latest post
There are no new unread posts for this topic. Specialized SWORKS Epic 29er - Large - XTR
7speedbandit
Thu Mar 07, 2013 4:14 pm
7speedbandit View the latest post
There are no new unread posts for this topic. Roval wheelset weight on Epic comp carbon 2013
in MTB
markdeep
Wed Jan 23, 2013 9:30 pm
theegeetee View the latest post
There are no new unread posts for this topic. LOOK KG 233 NOS Steel Weight Weenie
victorduraace
Sun Apr 14, 2013 9:07 am
victorduraace View the latest post
There are no new unread posts for this topic. Who is the tallest weight weenie?
Renatita81
31
2270
Mon Dec 31, 2012 8:06 pm
giant man View the latest post
It is currently Wed Jun 19, 2013 10:46 am
