Post new topic Reply to topic  [ 5 posts ]
 Post subject: 2x10 crankset choice
PostPosted: Tue May 22, 2012 3:32 am
I want to swap my m770 3x10 XT cranks for 2x10. I want lighter and a narrower q-factor. I would like to keep my current XT shifters and FD if possible but i still want good performance. I am looking at XX or XO in 26/39 and m980 XTR in 26/38. The SRAM q-factor is listed at 166 i cannot find info on the XTR. My current XT is 175 q-factor The prices are similar between them except the XTR comes with a BB. What do you think my best option would be?
 Post subject: Re: 2x10 crankset choice
PostPosted: Mon Jun 04, 2012 3:58 am
Be aware there are two XTR crank versions:
FC-M985 'Race' 2x10 only
FC-M980 'Trail' 3x10 and 2x10
The M985 has a narrower q-factor than the M980. Do a search the and figures are on here somewhere.
One important consideration with the M985 is that because of the low q-factor, the crank can clash with the chainstays of many frames. Do your research before buying. For instance my Cannondale Flash driveside chainstay has about a 2mm clearance with the M985 crank.
PostPosted: Mon Jun 04, 2012 6:50 am
XX also has a narrow version which is 156mm IIRC.
What bike is it going on?
PostPosted: Mon Jun 04, 2012 9:44 am
I have the X0 and I would recommend the XTR over it as the carbon really gets battered to the point that the very end of the arm starts 'flaking' bits of carbon. I've resorted to wrapping the ends in duct tape, similar to what Lightning cranks do with their rubber caps.
Norwood & Adelaide Uni CC
PostPosted: Sun Jun 10, 2012 2:00 am
If you do go with an XX or X0 cranks these beauties work very well and are very cheap:
http://raceface.com/components/small-parts/crank-boot/crank-boots/
Users browsing this forum: boots2000 and 9 guests
There are no new unread posts for this topic. Best 2x10 drivetrain?
in MTB
Philt
Tue Jul 03, 2012 3:43 am
boots2000 View the latest post
There are no new unread posts for this topic. 2x10 chairings setup - 42/30 or 40/28
in MTB
nonamed
Sat Apr 13, 2013 7:39 pm
nonamed View the latest post
There are no new unread posts for this topic. Silver cranks 2x10, any advice?
in MTB
wassertreter
Fri Apr 12, 2013 5:47 pm
Cheers! View the latest post
There are no new unread posts for this topic. Road bikes feeling the pressure of 2X10(11)?
elviento
13
1694
Thu Nov 01, 2012 6:13 pm
Valbrona View the latest post
There are no new unread posts for this topic. Attachment(s) 2012 SRAM XO 2x10 and 3X10 GRIPSHIFT FD compatibility
in MTB
godzuki26
Mon Sep 03, 2012 10:37 am
damond View the latest post
It is currently Tue May 21, 2013 11:02 pm
