Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sun May 20, 2012 8:07 pm
Hi,
Does anyone know if the Rotor rings for SRAM XX fits the SRM Holowgram SL 2*10 PM?
I looked on dr.cannondalestore.com and it seems like they had a lot of XX rings that would only fit a certain spyder (KP128 SS SI Spider 42z)?
My idea is to mount an SRM hollowgram SL MTB 2*10 on a Pressfit 91 frame, with the Rotor Rings made for the Specialized XX Spyder. The adapter for the frame I will get from Hellöre. Then I will get the KP0334 kit from drcannondale.com so that I also can use it on another frame with regular threaded 68mm. Has anyone here done this? What is the weight penalty for the adapters?
These rings: http://www.rotorbike.com/nueva/ingles/mtb_paraXX.ht
With this SRM Spyder: https://www.srm.de/store/product_info.p ... d09d23a69e
These cranks: http://www.cannondale-parts.de/epages/6 ... oductPrint
Thanks/Jens
PostPosted: Sun May 20, 2012 9:47 pm
I currently have bikes with both Cannondale SISL cranks and Rotor 3D+ cranks.
I suggest you just run a Rotor 3D+ crank on that bike with Rotor rings.
You will love the cranks and you will not have the hassles associated with the Cannondale cranks.
PostPosted: Mon May 21, 2012 3:40 am
i see no possible areas of interference between the crank arm, srm spider and rotor rings, so it should work. the bolt circles are, of course, the same, 120/80mm.
PostPosted: Mon May 21, 2012 6:21 am
What hassles are associated with the Cannondale cranks? Except the fact that I will have to use non standard adapters? I was under the impression that they were substantially lighter than the rotor 3D+
Also, delivery time on the SRM Rotor3D+ is 4 weeks, with the Cannondale I can get the cranks right away since they are not included with the SRM spider.
/Jens
PostPosted: Tue May 22, 2012 4:25 am
Cannondale cranks creak and their bob requires a lot of maintenance.
I have a set on my mtb now- I will never do that again.
Users browsing this forum: Bing [Bot], Google [Bot], handler and 9 guests
There are no new unread posts for this topic. 110 BCD Rotor Q Rings
in Wanted
KWalker
Fri Mar 29, 2013 6:48 pm
KWalker View the latest post
There are no new unread posts for this topic. Rotor No-Q 50/34 110 bcd rings
Dammit
Mon Mar 11, 2013 8:45 pm
Dammit View the latest post
There are no new unread posts for this topic. Best way to start with Rotor Q Rings
BoerLowie
36
3704
Mon Nov 19, 2012 12:12 am
1415chris View the latest post
There are no new unread posts for this topic. Attachment(s) Rotor Q-Rings 53-39 - $175 shipped CONUS OBO
btompkins0112
Fri Apr 19, 2013 9:37 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Extralite QRC-2 spider w/ Rotor Q Rings?
doomith
Fri Mar 01, 2013 8:40 am
Estuche View the latest post
It is currently Wed Jun 19, 2013 8:49 pm
