Post new topic Reply to topic  [ 11 posts ]
 Post subject: 2012 crossmax SLR noise
PostPosted: Sat May 05, 2012 9:48 pm
I need some help.
my rear wheel creakings under the first 0.25s of braking, and almost always creak upon pedaling. i can always generate the noise when I stand up to pedal. but sometimes when i sit to pedal under semi high torque, the sound is produced again.
1) my wheels have basically seen around 800km by now.
2) have true my wheels twice at 2 different LBS.
3) i tried mounting my old DT4.2D/370 hub wheels. and the sound is gone.( just to confirm it's coming from the mavic.)
4) i can just press my rear brake and use another hand to grab the wheel and just rock the wheel back and front to reproduce the sound
5) i swapped out the disc rotors.
my rear wheels is creaking the hell out of me.
I have tried WD40, finishline ceramic wet and wax lube.
i lubed both ends of the spokes. even the presta valve.
currently running rocket ron 2.1? with tubes.
i'm running out of ideas what to do with it. i do notice that the drive side has got higher tension then the non drive side.
question is the spoke tension still too low? or too high? or am i missing something? should i try swapping to the mavic skewers?( i dont have it at hand to try)
but the 4.2D/370 hubs wheels are not creaking even with the KCNC ti skewers.
details of bike that should be relevant for troubleshooting
titus FTM alum 09 frame, KCNC ti skewers, RT98 rotors, XTR 9 speed.
PostPosted: Sun May 06, 2012 2:11 am
Mavic skewers are notorious for creaking. Try switching them first.
TIME RXR
PostPosted: Sun May 06, 2012 5:16 am
but they are currently on kcnc ti skewers.
PostPosted: Sun May 06, 2012 7:44 am
ok, just rocked the wheel after doing these. it's silent now. O.O i wonder how long it will last.
1) clean out and finishline ceramic grease'd the 9mm mavic adapter and the frame's dropout.
2) clean out the hub, aka general mantainence.
3) injected ceramic wet lube into the bearings.
4) clean out the rubber seals on the freehub and greased the area that comes in contact with the hub
5) degreased and minimal wet lube on the paws.
6) changed both centre locks, cassette and rotors.
gonn take it out for a ride later to see howlong it can remain silent.
PostPosted: Sun May 06, 2012 8:07 am
ok. just went for a quick ride.
brake and regular sit and stand pedaling = silent. however when i lock into my PD-M980/spd and do full strength both pull and push, the chattering of the rear wheel comes back. sigh...
PostPosted: Sun May 06, 2012 1:54 pm
Are you 100% sure the noise is from the wheels? Have you got another wheelset you could try?
PostPosted: Sun May 06, 2012 2:21 pm
What cassette are you running? XX cassettes are known to creak.
PostPosted: Sun May 06, 2012 5:04 pm
i tried mounting with my previous DT wheels, transplanted the XTR CS-M970 11-32 and SM-RT98 rotors to the old DT wheels. totally silent. so yeah. 100% sure. that was the first thing i tried actually. because i couldnt confirm where the creaking/clattering sound was coming from.
I'm gonna try degreasing the paws to bone dry and try tightening up the weather seal cap later.
the mavic crossmax SLR 2012 as a cap on the non drive side that can be adjusted to setup for minimal drag or maximium weather seal.
"6) changed both centre locks, cassette and rotors" what i meant was i changed the centrelock on both the drive AND the non-drive side. i retained the cassette and rotors.
7) applied grease to the exterior of the freehub, (the area on the freehub that comes in contact with the cassette.)
PostPosted: Mon May 07, 2012 2:57 pm
the sound is still existent.
i tried something different today. I taped a plastic tire lever onto the seatstay, on the drive side. about 1-1.5mm away from the rim. I tightened the spokes on drive side only. basically shifting the rims 1-1.5mm towards the drive side and the creaking reduce even further. no almost non-existent, unless i crank ultra high torque.
the sound of the spokes on the ND = C-C#, drive side = A#-B (for those musically inclined. haha)
gawd i so hate mavic wheels. DT Swiss is so troublefree.
PostPosted: Mon May 07, 2012 3:33 pm
They're not supposed to be equally tight, are they? Plus, the spokes on the ND side are a bit longer, so maybe that's what's causing a lower pitch?
PostPosted: Tue May 08, 2012 3:41 pm
yeah i guess its suppose to be lower pitch on the ND side. i havent given it a ride yet. will do so later. hoping this solved the creaking.
Users browsing this forum: No registered users and 11 guests
There are no new unread posts for this topic. BMC Race machine 2012 vs Felt FC 2012
Larry_Pang
Wed Jun 13, 2012 6:12 am
justkeepedaling View the latest post
There are no new unread posts for this topic. SL4 NOISE HEADSET-BB ???
vagbouk
Wed Apr 03, 2013 11:04 pm
Marwin3000 View the latest post
There are no new unread posts for this topic. Flite Gel Flow noise
MaxDaddy
Mon Dec 31, 2012 4:31 pm
Zigmeister View the latest post
There are no new unread posts for this topic. Noise on the front wheel - HELP!!
cezinho
13
702
Fri Jul 27, 2012 7:49 pm
cezinho View the latest post
This topic is locked, you cannot edit posts or make further replies. Super Record Noise
brt570
Mon Sep 10, 2012 10:20 pm
bikerjulio View the latest post
It is currently Sun May 19, 2013 4:21 pm
