Post new topic Reply to topic  [ 12 posts ]
PostPosted: Tue May 01, 2012 12:04 pm
Is the Truvativ Noir GXP cank and BB cups compatible with Shimano Hollowtech II?
I measured both to have 24 mm diameter spindle so looks like they are but anyone mixed both e.g. (Shimano BB cups with the Truvativ crank)?
PostPosted: Tue May 01, 2012 12:47 pm
No, they are not compatible AFAIK.
my plastic bikes, 29ers & stable of old steel
PostPosted: Tue May 01, 2012 1:04 pm
Truvativ/SRAM tapers to 22mm on the NDS.
PostPosted: Tue May 01, 2012 1:43 pm
hmmm, I didn't spot that, 24 to 22 mm should be quite noticeable, a 1 mm step :shock: ; best photo I could find on t'web is this:
and another, since we all like pictures, right? :P
.... and so my confusion continues .... :(
maybe it is the "lands" on the spindle that are in different places for the two BBs?
PostPosted: Tue May 01, 2012 2:04 pm
why would you be confused? you have been given the correct answer. They are not compatible.
PostPosted: Tue May 01, 2012 2:09 pm
.... because if they are the same spindle diameter, how come they don't fit?
PostPosted: Tue May 01, 2012 2:48 pm
think you are missing the point, they are only the same size on the drive side, the NDS is 22mm on GXP.
http://www.bikyle.com/bottom_brackets.htm
PostPosted: Tue May 01, 2012 9:04 pm
The NDS bearing contacts the splined portion of the spindle, not the smooth section. You can actually see the step in the pictures you've provided on the splines.
As stated repeatedly above, they definitely are not compatible.
PostPosted: Wed May 02, 2012 11:28 am
ok, sorry if I appear to be non trusting but it is my nature to question whenever I see something but am told something else so I like to understand. :?
a close look at the chainset indeed showed polishing on the splined section where the ND bearing made contact, not the way I would have designed it but ......
I wonder if making a shim form a stip of 1 mm thick aluminium would work??? :noidea:
PostPosted: Wed May 02, 2012 1:04 pm
GXP BB is like $20-$30...
PostPosted: Wed May 02, 2012 1:49 pm
Hope make an adaptor so that you can use Truvativ / SRAM GXP cranks with their own BB, maybe one of those would fit a Shimano BB as well?
PostPosted: Thu May 03, 2012 4:40 am
They're incompatible, and that's that. Just buy a new BB, they're cheap. Don't futz around with shims or adapters, get the parts that work.
Users browsing this forum: No registered users and 7 guests
There are no new unread posts for this topic. Sram red compatible with shimano?
Bianchi10
Fri Mar 08, 2013 3:13 pm
eric View the latest post
There are no new unread posts for this topic. Shimano 11 compatible chain
captainclarko
Mon Mar 11, 2013 3:02 am
mann2 View the latest post
There are no new unread posts for this topic. Mavic R-sys slr 2012 - compatible with 11 speed Shimano?
klingej
Fri Jan 18, 2013 4:49 pm
klingej View the latest post
There are no new unread posts for this topic. Shimano chain connecting pins. 7801/7900 compatible?
WeightySteve
Wed Sep 19, 2012 11:01 am
WeightySteve View the latest post
There are no new unread posts for this topic. Truvativ stem T30 weight
in MTB
gelo354
Tue Dec 04, 2012 3:54 pm
socratease View the latest post
It is currently Sat May 25, 2013 1:13 pm
