It is currently Mon Jan 23, 2017 3:40 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: xt mech problem
PostPosted: Mon Apr 30, 2012 9:12 pm
upgraded my bike from slx 10 speed to xt 10 speed, changed shifter and rear mech but i cannot get it to shift properly
to get through the whole 10 sprockets only takes 6 clicks for some reason?
i'm normally good at sorting out my gears being a part time mechanic but this one's stumped me a bit
any help on this?
 Post subject: Re: xt mech problem
PostPosted: Mon Apr 30, 2012 10:04 pm
Maybe a silly question, but are you sure you have a 10 speed mech and shifter?
Only checking as 10 speed is a different cable pull ratio to 9 and below so not interchangeable. Fairly sure otherwise that the shadow mech cable routing is pretty foolproof (wrong side of pinch bolt makes little difference)
PostPosted: Mon Apr 30, 2012 10:09 pm
the shifter is definitely a 10 speed one as i bought it from chain reaction
the rear mech was bought 2nd hand and advertised as 10 speed but im beginning to think otherwise. is there a way of finding out whether it is 10 or 9? as far as i can see they're both shadow and both silver/black
PostPosted: Mon Apr 30, 2012 10:25 pm
If 10 speed there should be the dyna-sys "D" logo.
If you check the part number RDM772 (and lower numbers) is 9 speed, anything RDM780 and above is 10 speed.
PostPosted: Mon Apr 30, 2012 11:50 pm
right think i've got a 9 speed mech so will have to swap that for the slx 10 that it replaced.
alternatively what is the biggest sprocket anyone with a standard 10 speed road rear mech got away with?
PostPosted: Mon Apr 30, 2012 11:58 pm
cant use 10spd road rear mechs with 10spd mtb shifters
There are no new unread posts for this topic. Dura Ace 9070 Rear Mech Hanger stiff problem
TheDarkInstall
Sun Jun 05, 2016 5:47 am
TheDarkInstall View the latest post
There are no new unread posts for this topic. Long Cage Mech 11-36
OliverRB
36
1387
Sun Feb 21, 2016 2:38 pm
ultimobici View the latest post
There are no new unread posts for this topic. Rear mech hanger chain rub
tinchy
Thu Jun 30, 2016 5:25 pm
tinchy View the latest post
There are no new unread posts for this topic. WTD 2 x 34.9 Parlee front mech clamps
in Wanted
jonjones13
Mon Oct 31, 2016 10:23 am
jonjones13 View the latest post
There are no new unread posts for this topic. Ultegra Disc vs Mech how much weight
arevir
35
2030
Mon Apr 11, 2016 8:11 pm
Briscoelab View the latest post
Users browsing this forum: tonytourist and 5 guests
