Post new topic Reply to topic  [ 8 posts ]
PostPosted: Sun Apr 29, 2012 10:59 pm
Very solid brakes, but not as powerful as my R1's. I have a set of these on my Santa Cruz TRc and want to integrate the shifter and brake like on my XX's. Anyone seen any hardware to do this?
PostPosted: Sun Apr 29, 2012 11:48 pm
What shifters are you using? If XTR then you need SM-SL98-A
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/SL/EV-SL-M980-A-3310_v1_m56577569830799993.pdf
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Mon Apr 30, 2012 3:08 pm
crohnsy wrote:
I am using both Shimano XTR Race Brake M985 and XTR shifters. From that document, I don't see where the shifters integrate with the brakes using only a single mount?
PostPosted: Mon Apr 30, 2012 5:10 pm
You need these iSpec brackets...
http://www.pricepoint.com/detail/22758- ... s-Pair.htm
R2.5 / R3 / S-Works 29er (20 lbs) / S-Works SL4 Di2 (14.7 lbs)
PostPosted: Mon Apr 30, 2012 8:19 pm
http://www.pricepoint.com/detail/22758- ... s-Pair.htm" onclick="window.open(this.href);return false;
Just like I told him.
These brackets attach directly to the brake clamp
Flickr
Follow on Instagram
PostPosted: Mon Apr 30, 2012 9:18 pm
crohnsy wrote:
http://www.pricepoint.com/detail/22758- ... s-Pair.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Yeah what he said... Look at the center box on the tech doc. Item number 7 is the bolt and nutsert that slips into the brake lever mounting band/clamp. Swap out the top of the shifter, remove the brake lever mounting bolt, push the safety button and swing the clamp open, put the nutsert in the band, close the clamp, tighten the brake lever clamp then attach the shifter to the clamp and tighten.
PostPosted: Tue May 01, 2012 12:49 am
I see it now, thanks everyone! $82 is a lot of dough for 10mm of extra handlebar space!
PostPosted: Tue May 01, 2012 12:55 am
I got mine here... $65
http://www.chainreactioncycles.com/Mode ... elID=54860
Users browsing this forum: Google [Bot] and 14 guests
There are no new unread posts for this topic. XTR Race BR-M985, MCFK 31.6mm, Extralite UL3, Carbon IS-PM
Johnny_Yutah
Mon Feb 11, 2013 3:47 am
Johnny_Yutah View the latest post
There are no new unread posts for this topic. 1x10 for Shimano M985
in MTB
WolfTooth
Sun May 05, 2013 3:53 pm
WolfTooth View the latest post
There are no new unread posts for this topic. XTR M985 brake lever reversable?
in MTB
hjb1000
7
553
Wed Aug 22, 2012 3:34 pm
yourdaguy View the latest post
There are no new unread posts for this topic. XTR M985 Rear Disc Brake
in MTB
ipenguinking
Mon May 28, 2012 8:41 pm
purezerg View the latest post
There are no new unread posts for this topic. Innovative helmet with integrate light signals...
Powerful Pete
Thu Jun 21, 2012 6:04 pm
xjbaylor View the latest post
It is currently Tue May 21, 2013 10:29 pm
Shimano XTR disc brake Race
