It is currently Sun Sep 24, 2017 3:09 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Thu Apr 26, 2012 5:47 pm
Which rear road derailleurs have the correct actuation ratio (1:1) for Sram 9-speed grip shift? I'm thinking through a weenie solution for a flat bar commuter build. Would the SRAM 10-speed derailleurs (force or rival) work? Thanks!
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Thu Apr 26, 2012 8:18 pm
As far as I'm aware, none!
You could use a short cage 9 spd mtb mech though. (SRAM road and 10 spd mtb use a different cable pull to 9 spd).
Alternatively, you'll need shimano mech and shimano compatible gripshift.
PostPosted: Thu Apr 26, 2012 8:41 pm
Hmm. What about SRAM attack grip shift (for shimano) with a DA 7700(or 7800) RD? Seems like that should do it. Right?
PostPosted: Thu Apr 26, 2012 10:19 pm
that should work perfectly indeed. I use sram rockets (nearly the same as attack, just the rubber grips are different). You can also install a medium or large cage to a shimano road rear der. I would recommend to think about what rubber grips fit you better. I only like the ones of the X0. You can also purchase the X0 grip shifts too, then switch the rubbers and sell the X0 with the rubbers from the attack. I suggest this as it's much cheaper to buy the full x0 grip shifts rubber included, that buying the rubber grips separated.
Happy Trails !!!
PostPosted: Thu Apr 26, 2012 11:59 pm
Thanks, I'll probably remove the rubber grip and replace it with a piece of ESI foam.
PostPosted: Fri Apr 27, 2012 12:10 am
This bit of marketing ooze makes me think that a sram road der should work with sram twisties:
Quote:
When we launched our road technology from scratch we reapplied our MTB proven SRAM 1:1 actuation ratio...
Is it really not the same?
I'd like to go sram if possible because the RDs are lighter for the money and I already have an X0 rear shifter.
There are no new unread posts for this topic. Front shift quality - SR11 derailleur and other crank
silvalis
16
647
Sat Jul 22, 2017 12:14 pm
silvalis View the latest post
There are no new unread posts for this topic. Ultegra Di2 ST-R785 LEFT lever can shift Rear Derailleur?
andreszucs
10
504
Fri Jul 07, 2017 3:41 pm
andreszucs View the latest post
There are no new unread posts for this topic. Dura Ace 9100 front derailleur installation problems - can't shift into big ring
eric01
7
383
Fri Sep 22, 2017 5:28 am
eric01 View the latest post
There are no new unread posts for this topic. Sram red 10 speed shifters, front derailleur, 52t chainring, specialized mtb shoe
chris47
Wed Aug 02, 2017 7:01 pm
chris47 View the latest post
There are no new unread posts for this topic. Ultra low 11 speed road (Mt. Washington)
yesroh
7
1089
Tue Jun 13, 2017 8:12 am
Marin View the latest post
Users browsing this forum: No registered users and 2 guests
