Post new topic Reply to topic  [ 3 posts ]
PostPosted: Mon Apr 23, 2012 10:48 am
I have just converted to a 1x10 setup and installed a chain guide but because I am using Rotor Q rings its very trick not to get it slightly rubbing on one side or the other. I was thinking of a few solutions either:
1) Do I need 1? does anyone ride without a chain guide? I live in a pretty flat area where without any rocky sections to shake chain off
2) I have a few ideas of how to get round the rubbing situation but it would involve fashioning a design out of carbon fiber...which I haven't tried before
3) I have already attacked the chain guide device I have bought with a Dremel and cant really tune it any further...it is pretty good now and hardly rubs...should I just MTFU?
PostPosted: Mon Apr 23, 2012 3:15 pm
You probably will need a chain guide, I've tried running without one and the chain does eventually come off at some point. Depending on what chain guide you are using, you could try and space the cage that covers the chain away from its mounting point with a few thin washers. That's what I did with mine which is BB mounted. I slipped a couple of alloy washers between the BB mount and the cage, and it now runs without any rubbing. It does take a bit of trial and error to get it spot on, but it's worth it in the long run.
PostPosted: Mon Apr 23, 2012 3:37 pm
You could run a bash guard with a chain catcher on the inside but it would be pretty heavy. You definitely need something to keep the chain on, so if what you have is currently working I would keep it as is.
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
Users browsing this forum: No registered users and 12 guests
There are no new unread posts for this topic. Carbon chain guide?
in MTB
nrsnow
Fri Dec 21, 2012 7:01 pm
Dennis View the latest post
There are no new unread posts for this topic. Post your Chain Guide Setup
in Cyclocross / Touring
deek
Mon Jan 21, 2013 4:06 am
fastvegan View the latest post
There are no new unread posts for this topic. Attachment(s) Custom/homemade chain guide chainguide
in MTB
andreszucs
9
1209
Fri Feb 22, 2013 8:11 pm
andreszucs View the latest post
There are no new unread posts for this topic. 2011 scott spark 10 Chain guide Option HELP!
andreszucs
Thu Apr 11, 2013 6:51 am
There are no new unread posts for this topic. Colnago C59 Cable Guide
Lionlin
Sun Dec 30, 2012 5:34 am
Lionlin View the latest post
It is currently Thu Jun 20, 2013 11:53 am
