Post new topic Reply to topic  [ 24 posts ]
Go to page 1, 2  Next
 Post subject: Which 29er Leadville
PostPosted: Wed Apr 11, 2012 5:24 pm
I am not loving either but right now these are my options. Both fit, and cost about the same.
I will replace the bars, saddle and seatpost and most likely the stem on either bike anyway.
Giant xtc comp
Plus
++ Fox fork with 15mm axel
+ x9 2x10
Minus
Giant? Never been a fan of them
Weight...seams heavy, guessing over 25 lbs
Wheels..some cheezy in house brand
Scott scale expert
Plus
Seems very light sub 23lbs, I am guessing
DT Swiss xr39 wheels, do not know much about them but they have to be better than what comes on the giant.
Negatives
Rock shox Reba fork
XT and slx mix, Slx shifters and front der.
3x10
Interested to hear opinions.
TIME RXR
PostPosted: Wed Apr 11, 2012 6:34 pm
The new Reba is really good, and super light. Same for slx shifters. I say for the Scott scale!
 Post subject: Re: Which 29er Leadville
PostPosted: Wed Apr 11, 2012 7:21 pm
reba is a negative? I'd go with the scale for sure.
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Thu Apr 12, 2012 6:43 pm
Just came home with the Scott. swapped out the stem during the fitting. Put my saddle on when I got home. 22.8 lbs.
still going to put lighter bars and seatpost.
TIME RXR
PostPosted: Thu Apr 12, 2012 10:12 pm
triple rings is not such a bad thing. much less of a momentum killer when shifting rings. for leadville, you may even leave the granny ring at home- for the psychological edge only.
PostPosted: Thu Apr 12, 2012 11:26 pm
I will never ever use a 24-36. I am sure it would be faster to walk, or crawl on my belly.
TIME RXR
PostPosted: Fri Apr 13, 2012 3:11 am
I haven't ridden Leadville but have trained with some people who have done the running race, and I have ridden a lot in the area.
If you think you can ride up Telegraph on 32-36 you should probably be racing world cups. Even the lead group usually walk this, and in the running race many, many world class runners are left sitting on the hill, crying, with uncontrollable cramps.
The scott was the better choice.
PostPosted: Fri Apr 13, 2012 3:17 am
No, not a 32-36, but surely a 24-30 or 32. Sounds like there will be walking any way because of the log jam
TIME RXR
PostPosted: Fri Apr 13, 2012 3:56 am
I'm not a fan of Scott or Giant, but i think the REBA is a plus. I'd get the Scott.
Rapha cycling's Ed Hardy
PostPosted: Sat Apr 14, 2012 9:34 pm
Wondering if it is possible to remove the 24 and 32 chain rings and add a 28 for the middle?
Essentially making a 2x10 with the 42 and 28. Does anyone know if that will work?
TIME RXR
PostPosted: Sun Apr 15, 2012 4:58 am
32t is the smallest that will fit in the middle position, you have a 104bcd to contend with.
some people use a 27 or 28 in the INNER position, with the 42 or similar in the middle spot, nothing in the outer of course. chainline is a bit funny, but not as bad as one would think, as triple chainlines are biased to the outside right now anyways. clearance to the chainstays is iffy, though. you have to investigate that.
PostPosted: Sun Apr 15, 2012 5:18 am
if you think you can ride up telegraph at all you should probably be racing world cups. AFAIK, the only time it has been ridden up during the race was by Lance Armstrong and Dave Wiens...
You will need all the gears you can get for Leadville. It is brutally steep and at a retarded altitude.
PostPosted: Sun Apr 15, 2012 11:39 am
Location: somewere floating between here and the other side
im laughing my head off !! (-:
PostPosted: Mon Apr 16, 2012 1:49 am
Ok, its Powerline, not Telegraph. Its brutal b/c you have about 85 miles in your legs already. With the right gearing though, it can be ridden. I can clean Columbine and Powerline w/ my 20 x 34 granny gear in training. I felt strong on both climbs. I'm now on a 20 x 36 granny gear. A guy I know with similar fitness to myself rode the entire course, no walking at all, in about 8:40. He rode a HT 29er w/ a 20 x 36 granny gear too. I asked him if he could have made it in a 20 x 34. He said no way. He's one of 2 guys to finish every Leadville that's been raced. So, check your ego at the start line. Get a triple w/ an easy bail out gear. Riding is faster than walking. I've tried both and when I ride up, its faster. Plus, who wants to push their bike?? Not me. Its mountain bike riding, not pushing. Sometimes you gotta push and that's ok, but if you can set yourself up to succeed, then do it. Don't say, "well I'm going to have to walk anyway so I won't even try to ,I'll just use a 40/28 double". Your legs will be toast unless to train on a SS regularly and are accustomed to that much muscle tension for that many hours.
PostPosted: Mon Apr 16, 2012 3:33 am
Exactly... I will be walking the steeper parts anyway. So what difference will it make if I walk with the triple or double?
I like the idea of a 2x10 better. I will ride leadville 1x. I am sure I can manage without that gear, and I think that I will be forced to walk because of the mass of people, regardless of gearing.
And if I couldn't walk it faster than you could make it up in your 20x3? I could surely push you over :wink:
TIME RXR
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
Users browsing this forum: DrGalactus and 9 guests
There are no new unread posts for this topic. 2012 Cannondale Flash Carbon 29er 1 or Scalpel 29er 2?
in MTB
2002SaecoReplica
7
3199
Fri May 25, 2012 8:09 pm
steve07982 View the latest post
There are no new unread posts for this topic. Attachment(s) my 29er Ss
yogi29er
11
1377
Sat Jul 14, 2012 5:12 am
tonytourist View the latest post
There are no new unread posts for this topic. Attachment(s) 29er for a 164 cm. guy?
in MTB
gifted child
33
3182
Mon Nov 26, 2012 3:38 pm
limba View the latest post
There are no new unread posts for this topic. Considering building a HT 29er for XC
in MTB
53x12
13
3053
Thu Jun 28, 2012 11:39 am
michel2 View the latest post
There are no new unread posts for this topic. 29er Tires
in MTB
skiandbikecmh
9
1315
Sun Jun 03, 2012 5:07 pm
nspace View the latest post
It is currently Sun May 19, 2013 11:48 pm
