It is currently Fri Aug 18, 2017 11:19 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Mon Apr 02, 2012 6:46 am
I've got a tapered headtube and a 1 1/8" upper , 1 1/2" lower Alloy Heatset for it. can you link me what I need to use a straight steerer fork?
thanks.
PostPosted: Mon Apr 02, 2012 12:30 pm
Does this help?
http://wheelsmfg.com/headtube-reducer.html
There's sometimes a buggy.
One.
PostPosted: Mon Apr 02, 2012 6:10 pm
bikerjulio wrote:
hm, I guess that would work if I had a 1 1/8 headset. I already have a tapered headset though. is there anything else or do I have to get a new headset?
PostPosted: Mon Apr 02, 2012 6:54 pm
Gabe wrote:
Here you go.
http://www.jensonusa.com/FSA-Integrated ... ce-Reducer
PostPosted: Mon Apr 02, 2012 6:57 pm
This should work for you. Cane Creek makes one too.
http://www.jensonusa.com/!qnKZzElThd43k ... ce-Reducer" onclick="window.open(this.href);return false;
*edit* WrecklessREX posted while I was typing. Sorry
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Mon Apr 02, 2012 8:11 pm
source for a good alternative in Europe:
http://www.on-one.co.uk/i/q/HSFRREDDSET ... _11_8_inch" onclick="window.open(this.href);return false;
another disadvantage for "problem solver" shim is that it will add almost 1sm HT height :(
weight concerned = good, weight obsessed = bad!
PostPosted: Mon Apr 02, 2012 8:17 pm
thanks guys. does that fsa just slide onto the fork steerer? the one review for it on jenson said to make sure it supports the headset I will be using but I looked for it on the fsa website to find out what headsets are supported but I couldn't even find the product.
PostPosted: Mon Apr 02, 2012 8:27 pm
You just need to be sure that you're bearing diameter is the same as the FSA headset. Not much info on the jenson page.
What headset are you using? Try calling FSA for their input.
PostPosted: Tue Apr 03, 2012 7:06 pm
the headset I'm using is a neco one thats coming with the chinese carbon 29er frame. I found out the cane creek adapter will work with it so thats on the way.
PostPosted: Wed Apr 04, 2012 12:53 am
Where did you find the cane creek adaptor?
Ridley Excalibur
Scott Spark LTD 8.15kg (retired)
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
PostPosted: Wed Apr 04, 2012 3:50 am
http://www.competitivecyclist.com/za/CCY?PAGE=BUY_PRODUCT_STANDARD&PRODUCT.ID=8947&MODE=
the 40-series one works as well. for my headset thats coming with the china 29er frame, it needs to be the 52/30 size. competitive doesn't list the size but its suppose to be the 52/30, I ordered mine from bikerbob. other sites will usually list the size. theres 3 or 4 different sizes. let me know if you have more questions.
PostPosted: Wed Apr 04, 2012 3:56 am
For $10 I would definitely get the 110 version with the better seals.
For certain parts stiffer is more important than lighter.
PostPosted: Wed Apr 04, 2012 7:27 pm
The 110 is also listed as Alloy so it is probably a bit lighter than the steel 40 version.
PostPosted: Thu Apr 05, 2012 1:12 am
the 110 is 39g, the 40 is 14g, according to competitive, says actual weight.
There are no new unread posts for this topic. 53mm rake tapered fork (1/8 to 1/2)
istigatrice
Mon Aug 07, 2017 10:18 am
istigatrice View the latest post
There are no new unread posts for this topic. Fork for 2013 supersix evo 1.125->1.25 tapered
vejnemojnen
Fri Jul 07, 2017 1:13 pm
vejnemojnen View the latest post
There are no new unread posts for this topic. Suspension Fork 29" Straight steerer 9mm QR
in Wanted
GJMadone069
Wed Jun 28, 2017 3:30 pm
GJMadone069 View the latest post
There are no new unread posts for this topic. Attachment(s) Fork Needed - straight, carbon, 1" threaded steerer - suggestions?
dadoflam08
12
400
Wed Jul 26, 2017 11:31 am
dadoflam08 View the latest post
There are no new unread posts for this topic. Opinion needed regarding fork and headset.
Y26
Fri Jul 28, 2017 5:58 am
Y26 View the latest post
Users browsing this forum: No registered users and 4 guests
