How often do you open and regrease your grip shifts?
Hello, I was wondering if re greasing my grip shift will make them less noisy or not at all. I opened them recently because I had to substitute the rubber part as it was completely wasted, but i did not regrease them. Should I do it or it's not worthy at all? is a bit annoying to close them again and place teh spring in the right place and so on... thanks
Happy Trails !!!
- 2002maniac
- Contact:
I never have, but that doesn't mean it's a bad idea.
You could use slick honey or some similar light-body grease that won't attack plastic/rubber. Gripshifters come packed with something similar, but it appears impregnated with teflon, so it wouldn't hurt. However, its probably not going to reduce noise too much.
i just regreased them properly, haven't made any km after it. sound seems to be exactly the same. perhaps a tiny bit lower, and perhaps it works now a bit softer, but pretty much the same noise. it works a bit better though, they were kinda dry inside so i guess it was a good idea.
Happy Trails !!!
Whenever I change cables.
- Similar Topics
- Replies
- Views
- Last post
- 0 Replies
- 339 Views
Last post by mvcap
Sun Oct 22, 2017 5:04 pm
- 17 Replies
- 1774 Views
Last post by 3Pio
Tue Sep 12, 2017 4:24 pm
New to me: Open Cycle O-1.0
by Sacke » Tue Aug 15, 2017 8:18 pm » in Introduce Yourself / Gallery - Please use metric weights. - 4 Replies
- 1227 Views
Last post by Sacke
Wed Aug 16, 2017 9:14 am
- 4 Replies
- 585 Views
Last post by vanillaflyweight
Fri Nov 03, 2017 4:36 am
2018 Open U.P.
by aaronpass » Thu Mar 22, 2018 4:34 pm » in Introduce Yourself / Gallery - Please use metric weights. - 11 Replies
- 1097 Views
Last post by aaronpass
Mon Mar 26, 2018 5:15 pm
