It is currently Sat Mar 25, 2017 1:07 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Sat Mar 24, 2012 4:03 am
I'm going to buy a chinese 29er and the frame comes in bsa 68mm english thread or bb30. I can save money with going bsa 68mm since a slx crank is light and cheap, plus I can also save on getting a bb mounted mrp 1x guide instead of the seat tube mounted version thats double the cost. bb30 is stiffer though. so not sure what I should do. I'm planning to run 1x9
PostPosted: Sat Mar 24, 2012 5:26 am
Hollowtech II and GXP are really pretty good value for money options though and as you've mentioned, adding things like chain guide compatibility into the mix might make them a better choice for your needs.
In terms of future compatibility, there's nothing really wrong with using an English BB on a MTB at the moment because you can still fit most good 30mm cranks without too much hassle. Hollowgrams require a spindle with the bearing surfaces in a different place which is quite pricey but it's doable. The Sworks can also be made to fit using external cups on a 68mm frame - an excellent option if you can buy them online in the USA.
PostPosted: Sun Mar 25, 2012 9:07 pm
Withought second thought choose the bb30 version. Since you r determined to run only one disc in front the thicker axle of bb30 will take the stiffness and power transfer to a whole new level.
Which groupset are you going to built it with?
Sent using Tapatalk
PostPosted: Sun Mar 25, 2012 10:26 pm
Sent using Tapatalk
i weigh 125 pounds, is the bb30 stiffness going to make any difference for me? if i went bb30, I was going to get the truvativ aka 3.3 crankset and sram x9 shifters/derailleur.
PostPosted: Mon Mar 26, 2012 1:58 pm
I highly doubt you'll notice any difference between the SLX and the 3.3 crank. On a frame like the one you're looking at it's also unlikely the lay-up really changes in any way between the 2 different variants enough to make a noticeable difference in ride quality.
Yeah - if it were me picking the better budget option, I'd just pick the SLX, save money and have a cheaper/easier time with the chosen chain retention device.
PostPosted: Mon Mar 26, 2012 4:46 pm
I ended up buying the 68mm bsa version last night. I noticed from pics of both frames the bb area on the 68mm version has more carbon around it than the bb30 version, so maybe it'll be just as stiff. may not mean much but just something I noticed. cause they could have reduced the amount around it and had the tubes come down closer to the bb, which would have probably been less stiff.
no turning back now, lol.
There are no new unread posts for this topic. Best option for BB30 to GXP conversion (SS Evo frame)
welkman
12
985
Wed May 18, 2016 11:53 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Post your English
[ Go to page: 1 2 3 4 ]
sugarkane
58
4824
Tue Mar 07, 2017 11:22 am
Grill View the latest post
There are no new unread posts for this topic. Attachment(s) new domane slr on english site
[ Go to page: 1 2 3 4 5 ]
spartan
74
8566
Sat Jun 18, 2016 10:56 am
ansible212 View the latest post
There are no new unread posts for this topic. English, Hakkalugi, UP and Yampa
lmtup
Mon Oct 24, 2016 2:20 pm
lmtup View the latest post
There are no new unread posts for this topic. SOLD: ZIPP Vumaquad compact crank, English BB
Johnny Rad
Sat Mar 11, 2017 7:12 am
Johnny Rad View the latest post
Users browsing this forum: No registered users and 4 guests
