Post new topic Reply to topic  [ 21 posts ]
Go to page Previous  1, 2
PostPosted: Mon Mar 26, 2012 12:18 am
An update,I removed my 32-11 cassette and put on a 28-11 for the summer season.As would be expected,the 6700 plus the 28-11 block is working very well in the woods!!For further info,I did 30k on road and light trail with the 32-11 and 6700 without any problems,BUT I never went full hardcore offroad with this config.
PostPosted: Fri Mar 30, 2012 7:24 am
Without buying the actual hardware to try out first, is there anyway for me to know if I can use my DuraAce 7900RD with a MTB cassette (I'm current running 40t/28t chainrings with DA 9 speed road cassette)?
Please visit my blogs:-
I'm a MILF - er blog (Help raise awareness!) http://firespitter38.blogspot.com
True tales from the dark side http://truetalesfromthedarkside.blogspot.com
PostPosted: Fri Mar 30, 2012 8:16 am
Read the Shimano tech docs, it tells you what cassette teeth patterns you can sue with what, however 10-speed shiamno MTB and 10-speed road use different cable pull ratios and are not interchangeable, to run 10-speed road mech you have to use 10-speed road flat bar shifters.
Simon
PostPosted: Fri Mar 30, 2012 8:25 am
42/29 with 11-34 is at the limit already, I think for your 42/28, you can only use 11-32.
PostPosted: Sat Mar 31, 2012 6:03 pm
Simon
I don't think you've gone through those tech docs or the first post. The RDs mentioned in this thread are marked as 28t max but yet they are handling 32...
BTW XTR 970 shifters are compatible with DA7900 RD
PostPosted: Sun Apr 01, 2012 6:12 pm
Formerly known as Motaro
Tomstr wrote:
OK, i'm going to have to use the P-word. That thing is PORN!
My next rear-mech on the Commençal is going to be SRAM Force of RED for sure.
and sram red it works super even with mod to get to work with X.o
cannondale Rush carbon SL team 8.75kg/19.29 1x10
viewtopic.php?f=10&t=101405
old WW bikes
Epic carbon 2006 9.3kg
Spark 10 2008 8.2Kg
Anthem Adv 9kg ( solt after 3 weeks not done )
scalpel 2009 7.97kg
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
Users browsing this forum: Martin.F and 7 guests
There are no new unread posts for this topic. Another cross "newbie" question: rear road spacing on 135mm
in Cyclocross / Touring
LouisN
Sat Feb 23, 2013 12:46 am
LouisN View the latest post
There are no new unread posts for this topic. SL211 SuperLight rear hub / DA 7900 rear hub
headwind816
7
500
Fri Apr 19, 2013 9:59 pm
eric View the latest post
There are no new unread posts for this topic. Rear hub 20h
jasonliliong
Tue Jul 24, 2012 12:54 pm
racingcondor View the latest post
There are no new unread posts for this topic. New rear wheel?
in Everything wheels
skiezo
Sun Mar 17, 2013 6:29 pm
skiezo View the latest post
There are no new unread posts for this topic. 303 rear 404 front
project3
9
1095
Thu Jan 24, 2013 4:55 am
prebsy View the latest post
It is currently Thu May 23, 2013 7:45 am
