Post new topic Reply to topic  [ 10 posts ]
PostPosted: Sun Mar 11, 2012 9:17 am
anybody tried using 1.2 mm fishing line or strimmer line as replacement for steel gear wire?
it should be strong enough. As it may stretch a bit which, it may not work on the rear shifter but that should not be a problem for the font shifter.
PostPosted: Sun Mar 11, 2012 9:49 am
Powercordz cover his option. They aren't cheap but they are indeed very light. The end "bump" on them is aluminium and composite. The cord is made of zylon fibres, coated in some sort of nylon looking stuff. They do not stretch.
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Sun Mar 11, 2012 9:58 am
^^^ I know about Powercordz, but £ 35 for a pair vs £ 1.50 for 4+ pairs makes me want to try out the cheaper option. :? Making the end ferrule may be their downfall but I jave a couple of ideas..... :lol:
..... and Spinergy wheels use nylon (or some other not metal material) for spokes
PostPosted: Tue Mar 13, 2012 10:19 pm
the only thing I can think of that would work is braided fishing line, but that is quite a bit thinner... Monofilament stretches to much.
http://www.amazon.com/s/ref=nb_sb_noss_ ... re&x=0&y=0
PostPosted: Wed Mar 14, 2012 6:33 pm
I mysefl already had the same ideia, but never got to test it, but i know someone who tried it and said that was a no go, it stretch wayyy too much.
PostPosted: Thu Mar 15, 2012 12:58 pm
Was it fishing line that was tried?? I can imagine that needs to be quite stretchy to take the shock but I am looking into using trimmer line whcih may not be.
PostPosted: Thu Mar 15, 2012 5:52 pm
creep is the problem
PostPosted: Fri Mar 16, 2012 11:26 pm
He tried a very strong fishing line, i don't recall exactly for how much kilos it was, but was a lot.
After you do your experiment don't forget to post here too. :thumbup:
PostPosted: Mon Mar 19, 2012 8:02 pm
I didn't use a finish line, but the Powercordz works perfect with a XX rear derailleur.
PostPosted: Thu Apr 05, 2012 11:41 pm
Cheap, Light, Strong
You can only pick 2.
Just in in Race Cars........ Cheap, Fast, Reliable
Same deal, pick the 2 you want. You can't have all three.
"M"
2010 S Works SL3 Tarmac, Di2 with Hutchinson (Corima) Carbon tubeless
2010 S Works Epic, Sram XX with Carbon Roval Control SL
Users browsing this forum: No registered users and 13 guests
There are no new unread posts for this topic. Hollowgram chain line
neverwasbeen
13
584
Wed Apr 03, 2013 8:59 pm
shoemakerpom2010 View the latest post
There are no new unread posts for this topic. Risk using seatpost over stop line
Helmutti
21
1097
Sat Jan 12, 2013 3:28 am
Scott! View the latest post
It is currently Sun May 19, 2013 8:07 pm
