Post new topic Reply to topic  [ 46 posts ]
Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Mar 05, 2012 11:00 am
Sperstar chain guide is very light if your happy to run with no bash, otherwise lightweight bash and N-gear jump stop will work.
Simon
PostPosted: Wed Mar 07, 2012 11:21 pm
IMG_1540 by runningrunningjump, on Flickr
PostPosted: Wed Mar 07, 2012 11:22 pm
couldnt get the front mech to control the single ring with the front shifter removed so have added a 26t ring and the shifter.
PostPosted: Wed Mar 07, 2012 11:23 pm
IMG_1575 by runningrunningjump, on Flickr
PostPosted: Wed Mar 07, 2012 11:26 pm
picture above shows the new KCNC seat clamp which saves 28g! (38g vs 10g)
Thomson post 27.2 330 (235g)
Bontrager X lite seat (244g)
also shows 2 speed up front
PostPosted: Wed Mar 07, 2012 11:27 pm
IMG_1574 by runningrunningjump, on Flickr
IMG_1573 by runningrunningjump, on Flickr
PostPosted: Wed Mar 07, 2012 11:28 pm
IMG_1570 by runningrunningjump, on Flickr
PostPosted: Wed Mar 07, 2012 11:29 pm
IMG_1571 by runningrunningjump, on Flickr
IMG_1572 by runningrunningjump, on Flickr
PostPosted: Wed Mar 07, 2012 11:34 pm
youll also spot ive added a 2010 big volume Fox RP23 and i must say this is a fantastic upgrade over the old shock! i was shocked at the difference! not sure it shaved any weight though....
PostPosted: Wed Mar 07, 2012 11:35 pm
more suggestions for weight loss if youd be so kind???
PostPosted: Thu Mar 08, 2012 12:19 am
IMG_1577 by runningrunningjump, on Flickr
PostPosted: Thu Mar 08, 2012 10:58 am
Bin the front mech for a Superstar chain guide and loose the shifter, mech, cables and ring and bolts......even a lightweight bash and N-gear jump stop would be lighter (circa 160g versus about 360g as now).
Lighter discs, I can lock up an alligator windcutter (82g) just as easily as any other 160mm disc weighing 50% more, for the front you can get lighter discs, Hayes are lighter than most 160mm (118g) but will give good stopping.
Disc bolts, I found 2 lengths, the slightly shorter ones are 1g lighter a set (still steel!)
Grips, lockons are usually circa 80-100g, non lock on much lighter, foam (Pork rinds/KCNC/Avenir AGG407 are all the same actual part!) can be as light as 14g (with end caps).
Better RH shifter, Deore are about 20g heavier than XT and not as nice to use either.
Tyres.......
Simon
PostPosted: Fri Mar 09, 2012 3:19 pm
Thanks TheRookie!
Im looking into the chain guide idea more and might get the E.Thirteen XCX as this get the best reviews online! the MRP gets the worst but it is the cheapest so.....
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: No registered users and 12 guests
There are no new unread posts for this topic. 1x10 chainline
wassertreter
Mon Sep 10, 2012 10:11 am
wassertreter View the latest post
in MTB
wassertreter
Wed Oct 31, 2012 2:24 pm
There are no new unread posts for this topic. FSA 3 bolt chainrings - 1X10
in MTB
Steve Curtis
Mon Sep 24, 2012 11:41 pm
stephen@fibre-lyte View the latest post
There are no new unread posts for this topic. What bb30 Chainset for 1x10
in MTB
Steve Curtis
7
926
Thu Oct 04, 2012 12:38 pm
Steve Curtis View the latest post
There are no new unread posts for this topic. Di2 1x10/11 Hack, will this work?
in MTB
Toorqs
Sat Jan 05, 2013 7:27 am
Toorqs View the latest post
It is currently Fri May 24, 2013 11:08 am
